Author Topic: Can't set higher resolution after install but works in Live mode  (Read 681 times)
Offline some1
Peppermint 9.
Here is system info taken from Live session.
System:    Host: peppermint Kernel: 4.15.0-23-generic x86_64 bits: 64 Desktop: N/A
           Distro: Peppermint Nine
Machine:   Device: desktop Mobo: Foxconn model: 661 7MJ serial: N/A
           BIOS: Phoenix v: 6.00 PG date: 03/10/2006
CPU:       Single core Intel Celeron (-UP-) cache: 256 KB speed: 2666 MHz (max)
Graphics:  Card: Silicon Integrated Systems [SiS] 661/741/760 PCI/AGP or 662/761Gx PCIE VGA Display Adapter
           drivers: vesa (unloaded: modesetting,fbdev)
           Resolution: 1280x1024@0.00hz
           OpenGL: renderer: llvmpipe (LLVM 6.0, 128 bits)
           version: 3.3 Mesa 18.0.0-rc5
Audio:     Card-1 USB Audio Device driver: USB-Audio
           Card-2 C-Media driver: USB Audio
           Sound: Advanced Linux Sound Architecture v: k4.15.0-23-generic
Network:   Card: Silicon Integrated Systems [SiS] SiS900 PCI Fast Ethernet
           driver: sis900
           IF: enp0s4 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 160.0GB (0.6% used)
           ID-1: /dev/sda model: HITACHI_HTS54251 size: 160.0GB
Partition: ID-1: / size: 981M used: 35M (4%) fs: overlay dev: N/A
           ID-2: swap-1 size: 1.03GB used: 0.00GB (0%) fs: swap dev: /dev/zram0
Sensors:   System Temperatures: cpu: 43.0C mobo: N/A
Info:      Processes: 133 Uptime: 3 min Memory: 346.9/1961.4MB
And here after installation, fully updated.
pc@pc-desktop ~ $ inxi -Fz
System:    Host: pc-desktop Kernel: 4.15.0-23-generic x86_64
           bits: 64
           drivers: fbdev (unloaded: modesetting,vesa)
           Resolution: 640x480@73.00hz
           Sound: ALSA v: k4.15.0-23-generic
           driver: sis900
           mac: <filter>
Drives:    HDD Total Size: 160.0GB (4.1% used)
Partition: ID-1: / size: 146G used: 6.2G (5%)
           fs: ext4 dev: /dev/sda1
Info:      Processes: 151 Uptime: 7 min Memory: 506.4/1961.4MB
pc@pc-desktop ~ $
There is no other option besides 640x480 in Monitor setting.
Re: Can't set higher resolution after install but works in Live mode
« Reply #1 on: July 17, 2018, 02:39:50 am »
If you look closer to those outputs, you will see that in the live session you are using the vesa video driver. While on the installed system the one in use is fbdev.
You have a SiS900 PCI graphics card, so the correct driver should be video-sis.
I'm not in front of my laptop right now, but you could check if the xserver-xorg-video-sis driver is available in the repos?
apt-cache search xserver-xorg-video-sis
Or search for it using Synaptic package manager.
You could, alternativly, force the system to use the vesa driver instead of the fbdev.
A third alternative, would be to play with xrandr to see if you can get it to diplay the resolution you want. See, https://wiki.archlinux.org/index.php/xrandr
Regards
« Last Edit: July 17, 2018, 04:24:55 am by pin »
« Reply #2 on: July 17, 2018, 11:17:52 am »
Or maybe try adding vesa=791 as a kernel boot parameter and see if that makes a difference ?
Let us know if you don't know how to do that.
Offline crazysquirrel
  • Peppermint version(s): 8 - 32 bit
« Reply #3 on: July 26, 2018, 04:52:10 pm »
I had a post with the solution that would set resolution to 1024x768 I think but cannot find my post.
It is here in the forums *somewhere*.
I think I had to edit Grub but can't remember.
