Author Topic: CPU Fetch  (Read 962 times)
CPU Fetch
« on: July 13, 2018, 12:53:08 pm »
zebedee@i7-peppermint ~/cpufetch $ ./cpufetch
        ###                                             ###   Name:       Intel(R) Core(TM) i7-6700K CPU @ 4.00GHz
        ###                                             ###   Frequency:  4.30GHz
     #                    ###                ###        ###   N.Cores:    4 cores(8 threads)
   ##   ###   #########   ######   ######    ###        ###   AVX:        AVX,AVX2
  ##    ###   ###    ###  ###    ####  ####  ###        ###   SSE:        SSE,SSE2,SSE3,SSSE3,SSE4_1,SSE4_2
 ##     ###   ###    ###  ###    ###    ###  ###       ###    FMA:        FMA3
##      ###   ###    ###  ###    ##########  ###     ####     AES:        Yes
##      ###   ###    ###  ###    ###         ###   #####      SHA:        No
##       ##   ###    ###   #####  #########   ##  ###         L1 Size:    32KB(Data)32KB(Instructions)
###                                                           L2 Size:    256KB
 ###                                                          L3 Size:    8192KB
 ####                                        ####             Peak FLOPS: 550.40 GFLOP/s
There's different
https://github.com/Dr-Noob/cpufetch
Re: CPU Fetch
« Reply #1 on: July 13, 2018, 01:27:42 pm »
LOL .. you just like showing off don't you...
I'll bet you've hunted high and low for "gpufetch" :))
Re: CPU Fetch
« Reply #2 on: July 13, 2018, 01:30:32 pm »
I actually saw it on an Erik Dubois G+ feed  :)
and thought I will have some of that  :D
Re: CPU Fetch
« Reply #3 on: July 13, 2018, 01:38:25 pm »
We could make one that gives information only about blaupunkt USB sticks, and call it spot-fetch-stick :)
Okay that was what my son calls a "dad joke" :-[
Re: CPU Fetch
« Reply #4 on: July 13, 2018, 04:46:53 pm »
So, what do you use all that power for, anything in particular? Or is it there just because it's cool? ;)
Re: CPU Fetch
« Reply #5 on: July 13, 2018, 04:55:44 pm »
Personally, I've always liked HardInfo, available in the repositories:
That's the overview, I can also click on each core and get a lot of information on those. I can also benchmark the system with that program.
Re: CPU Fetch
« Reply #6 on: July 13, 2018, 04:59:00 pm »
Cool and future proofed :)
oh and I play Euro Truck Simulator 2  :P
Zeb...
Re: CPU Fetch
« Reply #7 on: July 13, 2018, 05:41:29 pm »
Because you never know when you'll need the horsepower so it doesn't hurt to have it....
In my case I used to have an AMD A10 quad core with 8GB RAM, that laptop used to take about 20 minutes to compress the squashfs for Peppermint and the laptop used to be worryingly too hot to touch by the time it was done. This Dell E series quad core i7 with 16GB takes about 2 minutes (if that)  by which time it's barely had time to raise a couple of degrees.
But sure it's overkill for the web browsing it generally does for the vast majority of the time.
As a side note - I've come to the conclusion Intel chips murder AMD at compression or probably anything floating point intensive. Or at least they did .. this may be old news now though with the Ryzens, which I gather have acquired a pretty good FPU themselves (?)
I didn't specifically buy the Dell for this, I bought it just because I could .. it was only when I did the PM8 respin ISO's I realised how damn fast it was at compression, with the added bonus it's built like a tank and makes me feel like the equivalent of a computing bodybuilder at a beach :))
So in my case, yeah I got the additional horsepower just to satisfy a mix of ego and enquiry .. but it turns out it actually has its uses :)
« Last Edit: July 13, 2018, 05:44:15 pm by PCNetSpec »
Re: CPU Fetch
« Reply #8 on: July 13, 2018, 07:22:14 pm »
No, a lot of CPU power is never a bad thing. And, those truck simulators are cool. I have the American one. :)
Re: CPU Fetch
« Reply #9 on: July 14, 2018, 01:09:26 am »
I keep forgetting about Hardinfo - Thanks
Re: CPU Fetch
« Reply #10 on: July 14, 2018, 01:33:45 am »
No problem. It's a great program with lots of great info about your system.
