Author Topic: Unable to install Greek system-wide [Solved]  (Read 606 times)
Offline CaptainNemo
« on: July 12, 2018, 06:22:38 am »
Hello, Peppermint users.
I've been using Peppermint 8 for about a year now and I'm completely satisfied with how the system works as well its ease of use, since I've been a Mint user for more than a decade. Nevertheless, trying to install the Greek language system-wide doesn't seem to work. Yes, Greek is ticked in the regional settings and, yes, I clicked on the "apply system-wide" button. Nothing seems to work, though.
I would appreciate any help.
Many thanks in advance.
« Last Edit: July 12, 2018, 04:29:59 pm by zebedeeboss »
Offline CaptainNemo
Re: Unable to install Greek system-wide
« Reply #1 on: July 12, 2018, 04:23:27 pm »
I dragged and dropped "Greek" in the first place in the Languages section after uninstalling and reinstalling the Greek language packages. I then clicked on "Apply system-wide" and it's done.
Sent from my Redmi 4X using Tapatalk
« Reply #2 on: July 12, 2018, 04:29:43 pm »
Hi CaptainNemo,
Welcome to the Forum
Good to hear you have resolved your issue.
I have marked this thread [Solved] for you.  If you could remember to do it on any further posts - it will help other users find answers that work.
Linux User #565092
Re: Unable to install Greek system-wide [Solved]
« Reply #3 on: July 13, 2018, 10:15:30 am »
Nice, great too hear you figured it out CaptainNemo :)
