Author Topic: HP Probook 6445b Lid problems(SOLVED)  (Read 858 times)
« on: July 04, 2018, 02:31:39 pm »
Hello Peppermint people, I'm having problems with the lid of this laptop, I can't get back into the system if I close the lid for a short time and then open it. I don't know if I'm supposed to press something special or what, if I press enter, nothing happens. Holding the power button down for a couple of seconds will light up all the lights, but no monitor awaking. I end up having to power down and then restart the laptop. This is strange to me because my Samsung laptop doesn't have this problem, I can just tap the power button and it wakes right up. Can somebody please guide me to the solution?  :'(
valentina@valentina-HP-ProBook-6445b ~ $ inxi -Fz
System:    Host: valentina-HP-ProBook-6445b Kernel: 4.15.0-23-generic x86_64
           bits: 64
Machine:   Device: laptop System: Hewlett-Packard product: HP ProBook 6445b serial: N/A
           Mobo: Hewlett-Packard model: 307E v: KBC Version 31.20 serial: N/A
           BIOS: Hewlett-Packard v: 68CTT Ver. F.05 date: 01/28/2010
Battery    BAT0: charge: 44.2 Wh 100.0% condition: 44.2/55.1 Wh (80%)
CPU:       Dual core AMD Athlon II M320 (-MCP-) cache: 1024 KB
           clock speeds: max: 2100 MHz 1: 2100 MHz 2: 2100 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RS880M [Mobility Radeon HD 4225/4250]
           drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
           Resolution: 1366x768@60.10hz
           OpenGL: renderer: AMD RS880 (DRM 2.50.0 / 4.15.0-23-generic, LLVM 6.0.0)
           version: 3.3 Mesa 18.0.0-rc5
Audio:     Card-1 Advanced Micro Devices [AMD/ATI] RS880 HDMI Audio [Radeon HD 4200 Series]
           Card-2 Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
           Sound: Advanced Linux Sound Architecture v: k4.15.0-23-generic
Network:   Card-1: Marvell 88E8072 PCI-E Gigabit Ethernet Controller driver: sky2
           Card-2: Broadcom Limited BCM43224 802.11a/b/g/n driver: bcma-pci-bridge
           IF: wlp9s0b1 state: up mac: <filter>
Drives:    HDD Total Size: 160.0GB (5.3% used)
           ID-1: /dev/sda model: WDC_WD1600BEKT size: 160.0GB
Partition: ID-1: / size: 146G used: 8.0G (6%) fs: ext4 dev: /dev/sda1
Sensors:   System Temperatures: cpu: 61.0C mobo: 37.6C
Info:      Processes: 163 Uptime: 6 min Memory: 496.2/3690.6MB
« Last Edit: July 04, 2018, 10:27:33 pm by alynur »
Re: HP Probook 6445b Lid problems
« Reply #1 on: July 04, 2018, 02:52:37 pm »
I`m wondering if I should have started this thread in Hardware?
« Reply #2 on: July 04, 2018, 06:23:06 pm »
If you'd like it moved, that's not a problem.
« Reply #3 on: July 04, 2018, 08:38:44 pm »
I think it may be best to move it, keep it with the other monitor threads. Thanks scifidude79.
« Reply #4 on: July 04, 2018, 08:47:51 pm »
No problem at all. I can't help with laptop lid issues, but I can at least move a thread. ;)
« Reply #5 on: July 04, 2018, 10:04:11 pm »
Well something is better than nothing. ;D
I think I fixed my problem, at least with it running on AC. I googled the problem and one gent suggested it's all in the power manager and to right click the battery icon. I had to select turn off monitor when lid is closed instead of suspend or lock. So far so good so I think I'll leave it at that and give the laptop back to my niece. I'm sure she'll let me know if she has any other problems.
