Author Topic: Hide mouse on login screen  (Read 588 times)
Offline razvan.birisan
« on: June 29, 2018, 12:49:21 pm »
Is there a way to hide my mouse cursor on the login screen  ?
Re: Hide mouse on login screen
« Reply #1 on: June 29, 2018, 01:00:33 pm »
AFAIK, I'm afraid not.
The slick-greeter configuration options can be seen here
https://github.com/linuxmint/slick-greeter
« Reply #2 on: June 30, 2018, 06:36:51 am »
Can I change its initial position ?
« Reply #3 on: June 30, 2018, 06:57:52 am »
As far as I can see, no.  It appears to default to the centre point of the screen's geometry,
« Reply #4 on: June 30, 2018, 12:40:08 pm »
These instructions are for Peppermint 9 ONLY .. if you're using any other version, STOP NOW
Okay, I've built a versions of slick-greeter (for Peppermint 9) that have a transparent cursor.
If you're still using Peppermint 8, DO NOT use the files attached below .. Peppermint 8 uses a different version of slick-greeter, trying these files in Peppermint 8 may result in a broken login screen .. you have been warned. ( twice now :) )
You can find them attached below, just download ONE of the two files (depending on your architecture) and double-click it to install.
Be sure to get the right architecture:-
For 64bit Peppermint 9, download slick-greeter_1.1.4-1+blank-cursor0.0.0_amd64.deb
For 32bit Peppermint 9, download slick-greeter_1.1.4-1+blank-cursor0.0.0_i386.deb
As i suggested, the cursor is still there, it's just blank/transparent .. you can see this by moving the cursor to the very top-right of the login screen and clicking, and you'll see the "Close" dialog will still appear.
If at any stage you want to get back to the original version of slick-greeter (with the cursor), just run:
sudo apt-get install slick-greeter=1.1.4-1
« Last Edit: June 30, 2018, 12:53:21 pm by PCNetSpec »
