Author Topic: Maximum resolution supported ?  (Read 806 times)
Offline arky217
« on: June 27, 2018, 04:43:13 pm »
I have a HP desktop, model 550-110 with a core i-3 4170 processor with HP 4400 integrated graphics running Peppermint 8. My current monitor is a 22" at 1920x1080 resolution at 60Hz.
I am thinking of buying a 27" monitor that has a max resolution of 2560x1440.
The use would be general web browsing, LibreOffice Writer, and watching Youtube videos.
(No gaming or photo editing)
The monitor would be at a viewing distance of 24"
(I'm hesitant of purchasing a 27" monitor with a 1920x1080 resolution as I wouldn't want the
view to be any less sharp than my present 22" monitor at 1920x1080.)
So, the question is, will my HP 4400 integrated graphics will support 2560x1440 at 60Hz ?
( The desktop output to the monitor would be HDMI )
( The HP specs for this processor for HDMI is 4096x2304 @ 24Hz, but I don't know what
that would be @ 60Hz ? )
My desktop specs:
System:    Host: jim-desktop Kernel: 4.13.0-45-generic x86_64 (64 bit gcc: 5.4.0)
Machine:   System: HP product: 550-110 v: 1.00
           Mobo: HP model: 2B2C v: 1.01 Bios: AMI v: A0.02 date: 07/03/2015
CPU:       Dual core Intel Core i3-4170 (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 14767
           clock speeds: max: 3700 MHz 1: 1637 MHz 2: 1914 MHz 3: 2204 MHz
           4: 1930 MHz
Graphics:  Card: Intel 4th Generation Core Processor Family Integrated Graphics Controller
           bus-ID: 00:02.0
           Display Server: X.Org 1.19.5 drivers: (unloaded: fbdev,vesa)
           Resolution: 1920x1080@60.00hz
           GLX Renderer: Mesa DRI Intel Haswell
           GLX Version: 3.0 Mesa 17.0.2 Direct Rendering: Yes
Audio:     Card-1 Intel 8 Series/C220 Series High Definition Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0
           Card-2 Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller
           driver: snd_hda_intel bus-ID: 00:03.0
           Sound: Advanced Linux Sound Architecture v: k4.13.0-45-generic
Network:   Card-1: Broadcom BCM43142 802.11b/g/n driver: wl bus-ID: 02:00.0
           IF: wlp2s0 state: down mac: <filter>
           Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: e000 bus-ID: 03:00.0
           IF: eno1 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 1120.2GB (3.6% used)
           ID-1: /dev/sda model: SanDisk_SDSSDA12 size: 120.0GB
           ID-2: /dev/sdb model: ST1000DM003 size: 1000.2GB
Partition: ID-1: / size: 99G used: 27G (29%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 12.81GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 29.8C mobo: 27.8C
Info:      Processes: 205 Uptime: 1:03 Memory: 1463.2/11935.6MB
           Init: systemd runlevel: 5 Gcc sys: 5.4.0
           Client: Shell (bash 4.3.481) inxi: 2.2.35
« Last Edit: June 27, 2018, 04:50:55 pm by arky217 »
Re: Maximum resolution supported ?
« Reply #1 on: June 28, 2018, 08:06:42 pm »
Depends how the monitor is connected.
The Intel 4400 graphics on your i3-4170  can handle:-
Max Resolution (HDMI 1.4) 4096x2304@24Hz
Max Resolution (DP) 3840x2160@60Hz
Max Resolution (eDP - Integrated Flat Panel) 3840x2160@60Hz (deosn't matter because that's refering to a laptop display)
Max Resolution (VGA) 1920x1200@60Hz
So if it's going to be connected via DisplayPort, then YES, it'll handle full 4k @ 60Hz
Does your system have a DP output (just because the chip can do it, doesn't mean HP added the port) ?
Info from here:
https://ark.intel.com/products/77490/Intel-Core-i3-4170-Processor-3M-Cache-3_70-GHz
Offline arky217
« Reply #2 on: June 28, 2018, 10:28:32 pm »
Info from here:
No, my desktop doesn't have a DP output; it just has VGA and HDMI outputs and I don't know
if the HDMI output is version 1.4 or not.
The HDMI output of 4096x2304@24Hz; any way from that spec. to determine
 if it would display 2560x1440@60Hz ?
(That's assuming that my HDMI version is 1.4)
