Author Topic: Serious bootproblems after installing Peppermint 9 alongside windows 10 (SOLVED)  (Read 8208 times)
Offline jozefmw
Re: Serious bootproblems after installing Peppermint 9 alongside windows 10
« Reply #90 on: September 19, 2018, 06:32:40 am »
Thank you for your reaction. That is, what I thought. So I am going to format in NTFS ... (SOLVED)
« Last Edit: October 01, 2018, 12:37:59 am by jozefmw »
« Reply #91 on: September 19, 2018, 03:11:28 pm »
I have been abroad for a while, working on a small laptop having problems too, using Peppermint 8. But I will come back to that later.
For now I am going to giving a new try to install Windows 10 and Peppermint 9, along side on my ZBook laptop.
So, first I have to wipe the whole harddisk, then getting Windows 10 in UEFI-mode and installing Peppermint 9 alongside in UEFI-mode too.
My first question:  I see that a general advice is too  format in FAT32. As my laptop has 32 GB Ram, I suppose I won't be able to use all that RAM, only 4 GB, unless I format , using NTFS. On all my other computers I use NTFS and Peppermint alongside, without problems ...
Filesystem type has nothing to do with RAM, I guess you're either confusing it with the fact the you must use 64bit Windows/Peppermrint to access all your RAM .. or the fact that FAT32 has a maximum file size of 4GB (ie. you cannot have any single file larger than 4GB which can be a pain these days when some video files are way bigger than that).
For Windows, format the partition as NTFS .. it doesn't suffer from the 4GB file size limit that FAT32 does.
For Linux you'll likely want to use EXT4 for the file system .. but the Peppermint installer will do this for you.
Offline jozefmw
« Reply #92 on: September 20, 2018, 02:52:39 am »
I did follow your instruction, installed Windows 10 again in UEFI-mode and started Peppermint 9 in  a live session.
I remembered, last time to have a lot of broken entries: You said: "your UEFI BIOS is for some reason remembering a LOT of old boot entries .. and they're all pointing to the wrong place", I cleqaned the whole list and now I wanted to check if there still were false entries, pointing to non-existing Ubuntu boot entries. So I was quite astonished that almost the some list of falese entries popped up again:
peppermint@peppermint ~ $  efibootmgr -v
BootCurrent: 0000
Timeout: 0 seconds
BootOrder: 0000,0001,0002,0003
Boot0000* Notebook Upgrade Bay BBS(CDROM,,0x0).......................................................................
Boot0001* Notebook Hard Drive BBS(HD,,0x0).......................................................................
Boot0002* USB Hard Drive 1 - Western Digital Elements 25A1 BBS(HD,,0x900).......................................................................
Boot0003* Notebook Ethernet BBS(128,,0x0)........................E..............................................
Boot0004* Notebook Ethernet BBS(128,,0x0)........................E..............................................
Boot0005* Windows Boot Manager HD(2,GPT,16d6ce18-c4b0-44e6-a007-d5ea6bdfd206,0xe1800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...d................
Boot0006* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0007* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0008* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0009* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot000A* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot000B* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot000C* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot000D* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot000E* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot000F* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0010* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0011* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0012* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0013* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0014* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0015* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0016* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0017* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0018* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0019* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot001A* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot001B* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot001C* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot001D* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot001E* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot001F* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0020* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0021* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0022* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0023* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0024* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0025* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0026* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0027* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0028* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0029* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot002A* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot002B* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot002C* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot002D* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot002E* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot002F* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0030* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0031* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0032* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0033* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0034* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0035* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0036* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0037* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0038* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0039* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot003A* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot003B* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot003C* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot003D* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot003E* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot003F* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0040* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0041* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0042* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0043* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0044* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0045* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0046* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0047* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0048* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0049* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot004A* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot004B* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot004C* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot004D* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot004E* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot004F* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0050* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0051* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0052* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0053* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0054* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0055* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0056* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0057* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0058* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0059* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot005A* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot005B* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot005C* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot005D* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot005E* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot005F* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0060* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0061* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0062* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0063* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0064* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0065* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0066* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0067* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0068* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0069* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot006A* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot006B* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot006C* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot006D* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot006E* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot006F* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0070* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0071* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0072* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0073* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0074* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0075* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0076* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0077* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0078* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0079* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot007A* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot007B* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot007C* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot007D* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot007E* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot007F* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0080* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0081* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0082* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0083* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0084* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0085* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0086* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0087* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0088* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0089* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot008A* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot008B* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot008C* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot008D* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot008E* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot008F* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0090* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0091* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0092* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0093* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
Boot0094* ubuntu HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi)
peppermint@peppermint ~ $  sudo fdisk -l
Disk /dev/loop0: 1.2 GiB, 1286332416 bytes, 2512368 sectors
Disk /dev/sda: 238.5 GiB, 256060514304 bytes, 500118192 sectors
Disklabel type: gpt
Disk identifier: 1EC71C14-C298-4C28-B608-F1121441B79A
Device       Start       End   Sectors   Size Type
/dev/sda1     2048    923647    921600   450M Windows recovery environment
/dev/sda2   923648   1128447    204800   100M EFI System
/dev/sda3  1128448   1161215     32768    16M Microsoft reserved
/dev/sda4  1161216 252512255 251351040 119.9G Microsoft basic data
Disk /dev/sdb: 1.8 TiB, 2000365289472 bytes, 3906963456 sectors
Disklabel type: gpt
Disk identifier: 29AA66E4-5438-4D09-85F3-5B5507691647
/dev/sdb1        2048 3230591174 3230589127  1.5T Microsoft basic data
/dev/sdb2  3230593024 3231641599    1048576  512M EFI System
/dev/sdb3  3231641600 3906961407  675319808  322G Linux filesystem
Disk /dev/zram0: 2 GiB, 2102648832 bytes, 513342 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
Disk /dev/zram1: 2 GiB, 2102648832 bytes, 513342 sectors
Disk /dev/zram2: 2 GiB, 2102648832 bytes, 513342 sectors
Disk /dev/zram3: 2 GiB, 2102648832 bytes, 513342 sectors
Disk /dev/zram4: 2 GiB, 2102648832 bytes, 513342 sectors
Disk /dev/zram5: 2 GiB, 2102648832 bytes, 513342 sectors
Disk /dev/zram6: 2 GiB, 2102648832 bytes, 513342 sectors
Disk /dev/zram7: 2 GiB, 2102648832 bytes, 513342 sectors
peppermint@peppermint ~ $ sudo blkid
/dev/sda1: LABEL="Recovery" UUID="F6585C05585BC2D3" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="77207d00-26d5-4bd9-836f-21abbd98f54c"
/dev/sda2: UUID="F45C-7ECE" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="16d6ce18-c4b0-44e6-a007-d5ea6bdfd206"
/dev/sda4: UUID="20A864CCA864A1D0" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="a28cb0e0-8e70-4562-9903-c74ad9ad1771"
/dev/sdb1: LABEL="F - ELEMENTS" UUID="7E4C4E9D4C4E4FD7" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="4de8ec1e-4aad-11e7-83fa-843497247882"
/dev/sdb2: UUID="2552-EBE1" TYPE="vfat" PARTLABEL="EFI System Partition" PARTUUID="a97cf69a-de76-4e49-b5a6-dd00261445a2"
/dev/sdb3: UUID="d5b2ac78-62e5-4170-93d4-78afa1b8f04d" TYPE="ext4" PARTUUID="e801b433-b6cc-41a1-ad69-50b7068f68a4"
/dev/sr0: UUID="2018-06-21-01-54-58-00" LABEL="Peppermint Nine" TYPE="iso9660" PTUUID="748cf612" PTTYPE="dos"
/dev/loop0: TYPE="squashfs"
/dev/sda3: PARTLABEL="Microsoft reserved partition" PARTUUID="6708e77f-9cd3-46bd-9b71-4015d10db8b6"
/dev/zram0: UUID="66237beb-3c1e-41de-8a60-f0602784b981" TYPE="swap"
/dev/zram1: UUID="aceb51c9-fd1a-471b-89c4-8d696d2bd648" TYPE="swap"
/dev/zram2: UUID="cee96158-9df3-4f81-b5f8-114f01c999c2" TYPE="swap"
/dev/zram3: UUID="dafa5d8e-0e65-4a5b-a57d-d84fc3433922" TYPE="swap"
/dev/zram4: UUID="7ae42e76-dc9b-40ab-972f-7333264481d1" TYPE="swap"
/dev/zram5: UUID="6197edab-5f7c-4791-826c-135962e97eab" TYPE="swap"
/dev/zram6: UUID="05764639-26d8-407a-b288-4071259cfb92" TYPE="swap"
/dev/zram7: UUID="0da36df8-71fa-4d97-b2a5-2604ae8f71d0" TYPE="swap"
S, I guess I have to delete again all the entries higher  than:
Boot0006* ubuntu   HD(2,GPT,35924e3e-fe73-4be0-99d4-4b146d4bcd99,0xe1800,0x32000)/File(\EFI\ubuntu\shimx64.efi) up to:
using the same terminal entries: sudo efibootmgr -Bb 0006 and so on.
My question is: do I have to put in the terminal these entries again, after having deleted the whole list?
Thank you so much for all your help ...
Offline jozefmw
« Reply #93 on: September 20, 2018, 04:01:24 am »
Anyway, I wonder how it is possible that these false entries show up again, after having deleted them last time?
« Reply #94 on: September 20, 2018, 04:25:01 am »
How big is the drive? HDD or SSD? Did you erase the disk before re-installing or did you just re-partitioned it?
EDIT: If you boot the live-usb and launch gparted, can you clearly identify the Windows recovery partition? You DON'T want to touch that one!!!
« Last Edit: September 20, 2018, 04:28:18 am by pin »
Offline jozefmw
« Reply #95 on: September 20, 2018, 05:20:47 am »
The SSD is 256 GB - in GParted: /dev/sda4 119.85 GiB   -   unallacoated 118.07 GiB   -  Partitions:
/dev/sda1 basic data partition - ntfs - Label: Recovery 450 MiB Used 296.97 MiB  - Unused 153.03 MiB - Flags hidden, diag
/dev/sda2 EFI system partition - fat32 - 100.00 MiB Used 23.93 MiB Unused 76.07 MiB - Flags boot,esp
/dev/sda3 Microsoft reserved partition - file system unkown 16 MiB  - - Flags msftres
/dev/sda4 Basic Data Partition - ntfs 119.85 GiB - Used:  55.66 GiB - Unused: 64.19 GiB - Flags:msftdata
ed: unallaocated 118.07 (This one, I would like to use for Peppermint 9. All my data always are on an external USB HD, as I use them on different computers. This external USB- HD, I mostly use for Peppermint, sometimes for Windows.
Offline jozefmw
« Reply #96 on: September 20, 2018, 10:38:38 pm »
In the mean time I deleted all the false entries, from Boot0006* ubuntu to Boot 0094* ubuntu-
This is what is left:
Disklabel type: gpt
Disklabel type: gpt
So, what would be my next step? Should I run again this:
sudo efibootmgr -c -g -d /dev/sda -p 2 -L ubuntu -l "\EFI\ubuntu\shimx64.efi"
sudo efibootmgr -c -g -d /dev/sda -p 2 -L peppermint -l "\EFI\ubuntu\shimx64.efi"
now post the output from:
sudo efibootmgr -v
sudo fdisk -l
sudo blkid
Offline jozefmw
« Reply #97 on: September 25, 2018, 07:27:11 am »
The first question remains:
why do all those false boot entries show up again after having deleted them, just by trying to reinstalling Peppermint?
Anyway, I did delete all of them again, as shown above, wondering what my next step could be.
« Reply #98 on: September 25, 2018, 07:32:44 am »
Is there a bios/firmware update for your system because it seems to be doing some odd stuff.
Offline jozefmw
« Reply #99 on: September 25, 2018, 09:22:58 am »
I did a bios update. Checked today again for new updates, using the installed HP service assistant:  there were none .
I just put in the commands you gave me before to check the boot situation. This is the outcome:
BootCurrent: 0000
Timeout: 0 seconds
Boot0002* Notebook Ethernet BBS(128,,0x0)........................E..............................................
Disklabel type: gpt
Disklabel type: gpt
/dev/zram0: UUID="0d92d3dc-d97c-413e-ad73-5affd16dfcf2" TYPE="swap"
/dev/zram1: UUID="893b0f81-1ad7-4cde-bd29-bd3d1f707d5d" TYPE="swap"
/dev/zram2: UUID="2c3a2c57-aa94-4083-a15f-e000fa75e1cd" TYPE="swap"
/dev/zram3: UUID="b8ec5521-1a5b-4a1e-b17f-95e7261442c3" TYPE="swap"
/dev/zram4: UUID="2f32741f-209d-41b1-ad1a-302a7f9a2dd2" TYPE="swap"
/dev/zram5: UUID="27ed40a0-70eb-4777-9ae3-d4fe464538f4" TYPE="swap"
/dev/zram6: UUID="54644115-0ec0-4e05-82ca-5a37084dbc7d" TYPE="swap"
/dev/zram7: UUID="ef517199-a012-4401-8686-09dfcbf64dd6" TYPE="swap"
I wonder what the next step is looking like ...
Offline jozefmw
« Reply #100 on: October 01, 2018, 12:37:33 am »
I give up ... and try anorher approach .
If your system keeps bunging \Windows back to the top of the boot order, the only solution I can think of would be to change the Windows bootloader to point at Ubuntu's bootloader, using bcdedit in Windows (EasyBCD gives you an easy GUI method for doing this).
https://askubuntu.com/questions/838780/windows-10-changes-uefi-boot-order-every-time
Offline johnny so-low
  • everyday's a new disaster
this worked wonders for me with grub2 errors almost lost my windows partition , but ten minutes and good as newhttps://www.supergrubdisk.org/
im a hillbelly i lay dwn & my belly makes a hill
