Author Topic: problems installing other terminals  (Read 453 times)
Offline Seadevil
« on: June 25, 2018, 03:10:38 pm »
next question,  I installed gnome-terminal   also   Terminator.  Neither one works.
1. gnome-terminal  says it installed in the peppermint terminal....but I can't find it anywhere in the menu.  doesn't show up.
2. Terminator is in the menu, but only opens the peppermint terminal ...nothing else.
how can i fix this?   There is no menu bar in peppermint terminal to change anything.
Re: problems installing other terminals
« Reply #1 on: June 25, 2018, 03:23:09 pm »
Do they work if you launch them from the terminal?
Offline Seadevil
« Reply #2 on: June 25, 2018, 03:58:11 pm »
ok,  SOMEHOW....i got both working via terminal.  thanks
« Reply #3 on: June 25, 2018, 06:26:51 pm »
Something is seriously wrong if the Terminator menu item launches the Peppermint Terminal, because it's "Exec=" line should read
Exec=terminator
I'd get it if it read
Exec=x-terminal-emulator
because that alternative point to sakura .. but it point DIRECTLY to terminator.
For Gnome Terminal to show up in the menu you'll have to run:
sudo xed /usr/share/applications/gnome-terminal.desktop
and change the line
Name=Terminal
to
Name=Gnome Terminal
and the line
OnlyShowIn=GNOME;Unity;
to
OnlyShowIn=GNOME;Unity;LXDE;
and save the file.
You'll then find it in the menu at
Menu > System > Gnome Terminal
« Last Edit: June 25, 2018, 06:28:51 pm by PCNetSpec »
  • Peppermint version(s): PM 9 & PM 8 Respin-2 (64-bit)
« Reply #4 on: June 25, 2018, 06:49:13 pm »
Is this a full, clean installation, or have you retained the /home folder from a previous older distro version?
