Author Topic: No available output devices - Sound Issues  (Read 1596 times)
Offline DeadZools
« on: July 24, 2014, 02:31:19 pm »
HI, I've just installed Peppermint 5 on my old Compaq Presario C700 and I've got everything running well, except there's no sound. I've searched all over and tried a few different things to no avail, if i click on the sound properties and go to hardware output devices there is nothing available to configure, i've installed all available updates and still nothing, what should i do?
Re: No available output devices - Sound Issues
« Reply #1 on: July 24, 2014, 02:35:00 pm »
Is there any output from:
aplay -l
or
sudo lshw -C multimedia
Offline DeadZools
« Reply #2 on: July 24, 2014, 09:16:19 pm »
I get
aplay: device_list:268: no soundcards found...
and as for the other command it asks for my password and then does nothing.
« Reply #3 on: July 25, 2014, 08:36:21 am »
Unless you've disaabled sound in the BIOS, you're going to need to go through
gedit /var/log/dmesg
and look for clues, as it doesn't appear the sond card is being detected at all.
Have you run a full system update and rebooted ?
Did audio work from the LiveCD/LiveUSB ?
Offline DeadZools
« Reply #4 on: July 26, 2014, 01:43:58 pm »
I couldn't find any relevant information in that log.. I never ran the live cd because this is a very old computer so its not exactly the quickest, I just went straight to the install. All I know is when it had Windows 7 on it the sound worked fine, and the sound card was there.  So I guess I'll find a different distro to play with, Peppermint seems a little too quirky and buggy for me anyway. thanks for the help :/
