Author Topic: VGA monitor with Dell 1545 inspiron laptop Solved.  (Read 687 times)
Offline tms54
  • Peppermint version(s): 9 64 bit
« on: June 23, 2018, 03:32:17 pm »
Never mind, stupid mistake on my part, a missing hyphen.  Duh.  I feel like a fool. But, lovin it on this elderly laptop.  Cannot get persistent resolution on VGA.  I have the xrandr settings, have used them often.  It works during a session via terminal or executing.  (#!/bin/bash
xrandr --newmode 1280x800  83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync
xrandr --addmode VGA-1 1280x800
xrandr --output VGA-1 --mode 1280x800)  Added it to session and startup, no go as it always has in Linux Lite, Mint XFCE, Mate, etc.  Nor does it work when adding , 91_custom_xrandr to  /etc/X11/Xsession.d as I have also done as recently as Linux Lite 4 and Mint 19  (xrandr --newmode 1280x800  83.50  1280 1352 1480 1680  800 803 809 831 -hsync +vsync)
xrandr --addmode VGA-1 1280x800     Both also work fine on Pep 8  Suggestions? No joy with arandr either. Thanks. Typing this on Pep 8.
« Last Edit: June 23, 2018, 03:57:54 pm by tms54 »
Re: VGA monitor with Dell 1545 inspiron laptop Solved.
« Reply #1 on: June 23, 2018, 06:47:27 pm »
You could try switching back from xfce4-display-settings to lxrandr.
Run:
sudo apt-get install lxrandrnow navigate to
Menu > Settings > Default applications for LXSession
Select the "Autostart" tab
Remove the tick from "Xfsettingsd"
then log off/on
Youll then need to change any monitor settings from:-
Menu > Settings > Monitor Settings
(and not "Display")
But maybe your startup script will work now ?
