Author Topic: Peppermint 9 - GIMP 2.10.2  (Read 2414 times)
« on: June 22, 2018, 07:38:38 am »
For those that don't want the snap version of GIMP 2.10.2, we have it as a .deb version in this PPA
https://launchpad.net/~peppermintos/+archive/ubuntu/gimp-2.10.2
If you install GIMP from Software Manager or Synaptic you'll currently end up with version 2.8, or you can install version 2.10.2 as a snap from within Gnome Software (in the menu at Menu > System > Software)..
But if like me you'd like 2.10.2, but don't like snap/flatpak packages, and the way they:-
a) take up TONS of space on your system (duplicating dependencies for no good reason)
b) don't integrate into the system theming properly (so end up looking different to everything else)
Here's how to get it as a .deb, and set the theme to match the rest of the system.
Open a terminal and run:
sudo add-apt-repository ppa:peppermintos/gimp-2.10.2then
sudo apt-get updatethen
sudo apt-get install gimp gimp-plugin-registry gmic geglyou should now find GIMP 2.10.2 in your menu at:-
Menu > Graphics > GIMP Image Editor
By default, GIMP 2.10.2 opens with its own dark theme, but if you want it to use the same theme as the rest of your system, open GIMP then navigate to:-
Edit > Preferences > Interface > Theme
and set it to "System".
To UNDO
To remove GIMP 2.10.2 and go back to version 2.8, run these 2 commands
sudo apt-get install ppa-purgethen
sudo ppa-purge ppa:peppermintos/gimp-2.10.2
We've done it this way rather than just replacing 2.8 in the main repos so you have a choice between 2.8 and 2.10 .. take your pick ;)
« Last Edit: June 22, 2018, 02:09:28 pm by PCNetSpec »
