Author Topic: (SOLVED) How can I make a folder shortcut on the desktop?  (Read 4861 times)
Offline jozefmw
« on: July 24, 2014, 06:10:56 am »
Must be possible, is it not?   :-\
« Last Edit: July 24, 2014, 11:27:15 pm by jozefmw »
Re: How can I make a map shortcut on the desktop?
« Reply #1 on: July 24, 2014, 06:13:48 am »
You've lost me .. a shortcut to what ?
Offline jozefmw
Re: How can I make a folder shortcut on the desktop?
« Reply #2 on: July 24, 2014, 06:53:17 am »
a shortcut (symbol) of a an existing folder on the desktop.
 For instance:
In a USB HD I have a map wich I would like to open through a desktop Icon.
How can I create that shortcut icon?
« Last Edit: July 24, 2014, 09:28:06 am by jozefmw »
« Reply #3 on: July 24, 2014, 07:13:32 am »
Does double clicking on the map open it ? .. in which application ?
What is the path to the map file (including its name) ?
Offline jozefmw
« Reply #4 on: July 24, 2014, 07:29:29 am »
The pathname is:
/media/elias/Verbatim/Current D1
When opening the map I just get the list of the files within.
« Last Edit: July 24, 2014, 09:28:39 am by jozefmw »
« Reply #5 on: July 24, 2014, 08:39:18 am »
OK, can you host the map somewhere (and provide a link), so I can download it and try to work out which application is needed to open it.
or do you know which application will open it ?
If you don't want the link to be public .. post it to me in a personal message.
Offline jozefmw
Re: How can I make a shortcut of a folder on the desktop?
« Reply #6 on: July 24, 2014, 09:25:32 am »
As I understood that  there is basicaly a question of misunderstanding I realised That I am using the wrong word.
I was talking about creating a shortcut of a folder, which in my lingo is called a map.  ::)
So sorry for that, but I m not very much used to the english appelations.
I also changed the title of the post.
« Reply #7 on: July 24, 2014, 09:38:55 am »
Ahh, I just realised that in your other topic ;)
Anyway, creating a soft symlink to that folder is easiest .. run:
ln -sv <path to target> <path to where you want the symlink and its name>
(being careful to surround the paths in quotation marks if they contain any spaces)
so in this case
ln -sv "/media/elias/Verbatim/Current D1" "/home/elias/Desktop/Current D1"
Offline jozefmw
« Reply #8 on: July 24, 2014, 11:00:17 am »
I guess, we are almost there ....
This did not work. May be because that folder is on a Windows partition.
But I remember that in Peppermint 4 I had shortcuts of various Windows folders on my desktop.
Although I am Dutch and living in Holland, I am using Peppermint in German with a German keyboard
 because I have to work a lot with German Texts.
This is what I got:
elias@elias-System-Product-Name ~ $ ln -sv "/media/elias/Verbatim/Current D1" "/home/elias/Desktop/Current D1"
ln: Die symbolische Verknüpfung »/home/elias/Desktop/Current D1“ konnte nicht angelegt werden: Datei oder Verzeichnis nicht gefunden
It means that the folder could not be created because the folder could not be  found.
« Reply #9 on: July 24, 2014, 12:20:13 pm »
try
ln -sv /media/elias/Verbatim/"Current D1" /home/elias/Desktop/"Current D1"if that still doesn't work .. post the output from:
ls -a /media/elias/Verbatim
Offline jozefmw
« Reply #10 on: July 24, 2014, 02:50:02 pm »
The first one didn't work either.
The second one gives this output:
elias@elias-System-Product-Name ~ $ ls -a /media/elias/Verbatim
02. De structuur van onze sturingen.doc
$AVG
BackUps
Blog.txt
Coralie-Channeling 14.02.19.pdf
Current D1
Current D2
Current D3
Current E0
Current E1
Current Linux
D2
D2 (2)
Dell 6400
DERBAER
Download Managers
DR-05-Handbuch.pdf
driverupdater.exe
Es werde LICHT
FOTO
found.000
fraglist.luar
gcb.exe
Genezen door Klanken.pdf
.html
INTENSO-USB (U) - Verknüpfung.lnk
iobituninstaller_338.exe
Link to Current D1
Link to Current E0
Link to FOTO
mbae-setup-1.03.1.1220 (1) (1).exe
mbae-setup-1.03.1.1220 (1).exe
mbae-setup-1.03.1.1220.exe
merged_partition_content
msdownld.tmp
Papierkorb - elias.9990@gmail.com - Gmail.htm
proxtube (1).crx
proxtube (2).crx
proxtube.crx
$RECYCLE.BIN
RECYCLER
RogueKillerX64 (1).exe
SIRONJAS
System Volume Information
Test Linux.odt
.Trash-1000
Untitled Folder
VERBATIM HD_files
vlc-2.0.5-win64 (1).exe
Volume (D) - Verknüpfung.lnk
Windows 8 & Linux startproblem_files
Windows 8 & Linux startproblem.html
elias@elias-System-Product-Name ~ $ ^C
« Reply #11 on: July 24, 2014, 03:08:27 pm »
OK, this is confusing
Does this fail:
ls -a /media/elias/Verbatim/"Current D1"
and what's the output from:
ls /home/elias
« Last Edit: July 24, 2014, 03:19:15 pm by PCNetSpec »
Offline josephd
  • Peppermint OS Website Admin
    • LinuxBookPro
« Reply #12 on: July 24, 2014, 10:49:35 pm »
Hi jozefmw,
Have you tried simply dragging and dropping the folder from the media to your desktop while holding down Ctrl + Shift?
That should create an alias to any file and should work when the drive is available.
Screenshot example of my desktop with an alias to a usb stick
http://www.linuxbookpro.com/wp-content/uploads/2014/07/alias-screenshot.png
« Last Edit: July 24, 2014, 10:58:17 pm by josephd »
Offline jozefmw
(SOLVED) Re: How can I make a folder shortcut on the desktop?
« Reply #13 on: July 24, 2014, 11:26:09 pm »
Thank you Josepd,
That was the solution.
I thank all the others too, who put time and energy in trying to solve the problem !!!  ;D
Re: (SOLVED) How can I make a folder shortcut on the desktop?
« Reply #14 on: July 25, 2014, 05:21:27 am »
Jeez .. now I feel stupid  :-[
How long has that been possible in PCManFM ? .. I could have sworn it wasn't  :-\
