Author Topic: Update error - no public key (solved)  (Read 516 times)
Offline razvan.birisan
« on: June 22, 2018, 05:55:16 am »
I've got the following error:
W: Eroare GPG: http://download.opensuse.org/repositories/home:/selmf/xUbuntu_16.04  Release: Următoarele semnături n-au putut fi verificate, deoarece cheia publică nu este disponibilă: NO_PUBKEY 3F3411BE43F8BC1F
W: The repository 'http://download.opensuse.org/repositories/home:/selmf/xUbuntu_16.04  Release' is not signed.
I've tried:
sudo apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv 3F3411BE43F8BC1F
and the second approach from http://opensourceforgeeks.blogspot.com/2013/04/w-gpg-error-httpppalaunchpadnet-precise.html
None of them worked. :'(
How can I fix it ?
« Last Edit: June 22, 2018, 09:04:25 am by razvan.birisan »
Offline TonyBronze
  • Peppermintaholic
Re: Update error - no public key
« Reply #1 on: June 22, 2018, 07:31:37 am »
Try:
wget -nv https://download.opensuse.org/repositories/home:selmf/xUbuntu_16.04/Release.key -O Release.key
sudo apt-key add - < Release.key
sudo apt-get update
« Reply #2 on: June 22, 2018, 09:04:02 am »
It worked. Thanks. :)
Re: Update error - no public key (solved)
« Reply #3 on: June 22, 2018, 04:41:18 pm »
Nicely done Tony :)
