Author Topic: Can't adjust brightness, particularly with Fn keys.  (Read 2436 times)
Offline Sgthawker
  • Peppermint version(s): 10R
« on: June 20, 2018, 06:21:05 pm »
My laptop F1 thru F12 don't all work. While holding the Fn Key and pressing the appropriate key the screen control keys don't work, but the dim/bright keys do show the box with increasing/decreasing brightness bar, without affecting brightness or turning off the display. I can't adjust the screen brightness at all with the bright -/+ via the battery icon or via Peppermint settings either for the difference that may make. The internal/external key also does not work. The rest as indicated below do work:
Fn 1  Sleep                  Works
Fn 2  Airplane Mode            Works
Fn 3  Keyboard Backlight -              Works
Fn 4  Keyboard Backlight +      Works
Fn 5  Screen Dim                    Not
Fn 6  Screen Bright            Not
Fn 7  Screen Off                    Not
Fn 8  Internal/External Monitor   Not
Fn 9  Touchpad Disable/Enable   Not
Fn 10 Mute                  Works
Fn 11 Audio -                       Works
Fn 12 Audio +                       Works
My Peppermint 8 Respin inxi:
sarge@GL502VMK-Peppermint ~ $ inxi -Fxz
System:    Host: GL502VMK-Peppermint Kernel: 4.13.0-43-generic x86_64 (64 bit gcc: 5.4.0)
Machine:   System: ASUSTeK (portable) product: GL502VMK v: 1.0
           Mobo: ASUSTeK model: GL502VMK v: 1.0
           Bios: American Megatrends v: GL502VMK.305 date: 07/03/2017
CPU:       Quad core Intel Core i7-7700HQ (-HT-MCP-) cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 22464
           clock speeds: max: 3800 MHz 1: 1157 MHz 2: 927 MHz 3: 1251 MHz
           4: 1957 MHz 5: 952 MHz 6: 2021 MHz 7: 958 MHz 8: 1036 MHz
Graphics:  Card: NVIDIA Device 1c60 bus-ID: 01:00.0
           Display Server: X.Org 1.19.5 drivers: nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1920x1080@60.02hz
           GLX Renderer: GeForce GTX 1060/PCIe/SSE2
           GLX Version: 4.5.0 NVIDIA 384.130 Direct Rendering: Yes
Audio:     Card Intel Device a171 driver: snd_hda_intel bus-ID: 00:1f.3
           Sound: Advanced Linux Sound Architecture v: k4.13.0-43-generic
Network:   Card-1: Intel Wireless 8260 driver: iwlwifi bus-ID: 03:00.0
           Card-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: d000 bus-ID: 04:00.0
           IF: enp4s0 state: down mac: <filter>
Drives:    HDD Total Size: 1128.6GB (16.1% used)
           ID-1: /dev/nvme0n1 model: N/A size: 512.1GB
           ID-2: /dev/sda model: SanDisk_SDSSDH31 size: 1000.2GB
           ID-3: USB /dev/sdb model: Voyager_GT_3.0 size: 128.3GB
Partition: ID-1: / size: 29G used: 6.9G (26%) fs: ext4 dev: /dev/nvme0n1p6
           ID-2: swap-1 size: 26.21GB used: 0.00GB (0%) fs: swap dev: /dev/nvme0n1p9
Sensors:   System Temperatures: cpu: 51.5C mobo: N/A gpu: 0.0:42C
Info:      Processes: 223 Uptime: 22 min Memory: 866.7/24057.6MB
           Init: systemd runlevel: 5 Gcc sys: 5.4.0
           Client: Shell (bash 4.3.481) inxi: 2.2.35
Searching these forums has not led to finding this issue in particular. What might I do to get this working?
Note: They all seem to work fine with a multiboot Linux Mint 18.3 KDE install on this same laptop.
Re: Can't adjust brightness, particularly with Fn keys.
« Reply #1 on: June 20, 2018, 09:35:06 pm »
Hi Sqthawker,
Please hold tight - we will get you a solution shortly.  We are extremely busy atm testing the next Version of Peppermint and getting it ready for release.
Offline Sgthawker
« Reply #2 on: June 21, 2018, 06:31:10 pm »
Thanks for the reply. Waiting patiently for P-9.
 8)
« Reply #3 on: June 22, 2018, 01:45:59 pm »
Peppermint 9 is already out Sgthawker.
Offline Sgthawker
« Reply #4 on: June 22, 2018, 03:21:08 pm »
Thanks, PCNetSpec, I just downloaded it and will give it a try.
Offline Sgthawker
« Reply #5 on: July 06, 2018, 07:13:49 pm »
Well, it seems the issue persists as noted above, except it is with Peppermint 9 instead of PM 8 respin. I have a new inxi:
sarge@GL502VMK-PM9 ~ $ inxi -Fxz
System:    Host: GL502VMK-PM9 Kernel: 4.15.0-23-generic x86_64 bits: 64 gcc: 7.3.0
Machine:   Device: laptop System: ASUSTeK product: GL502VMK v: 1.0 serial: N/A
           Mobo: ASUSTeK model: GL502VMK v: 1.0 serial: N/A
           UEFI: American Megatrends v: GL502VMK.305 date: 07/03/2017
Battery    BAT0: charge: 61.5 Wh 100.1% condition: 61.5/64.4 Wh (95%)
           model: ASUSTeK ASUS status: Discharging
           hidpp__0: charge: 85% condition: NA/NA Wh
           model: Logitech Anywhere MX status: Discharging
CPU:       Quad core Intel Core i7-7700HQ (-MT-MCP-)
           arch: Skylake rev.9 cache: 6144 KB
           clock speeds: max: 3800 MHz 1: 2310 MHz 2: 3208 MHz 3: 3369 MHz
           4: 3167 MHz 5: 3244 MHz 6: 2968 MHz 7: 3151 MHz 8: 3186 MHz
Graphics:  Card: NVIDIA GP106M [GeForce GTX 1060 Mobile] bus-ID: 01:00.0
           drivers: nvidia (unloaded: modesetting,fbdev,vesa,nouveau)
           OpenGL: renderer: GeForce GTX 1060/PCIe/SSE2
           version: 4.6.0 NVIDIA 390.48 Direct Render: Yes
Audio:     Card Intel CM238 HD Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.15.0-23-generic
           Card-2: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
Drives:    HDD Total Size: 1512.3GB (4.8% used)
           ID-1: /dev/nvme0n1 model: Samsung_SSD_960_PRO_512GB size: 512.1GB
Partition: ID-1: / size: 29G used: 5.3G (20%) fs: ext4 dev: /dev/nvme0n1p6
Sensors:   System Temperatures: cpu: 53.5C mobo: N/A gpu: 0.0:49C
Info:      Processes: 230 Uptime: 16 min Memory: 1315.8/24057.3MB
           Init: systemd runlevel: 5 Gcc sys: 7.3.0
           Client: Shell (bash 4.4.191) inxi: 2.3.56
I can use xrandr to reduce brightness, but I must apply at each boot, and would prefer settings to retain brightness across boots and be easily adjusted.
Thanks for any replies!
« Reply #6 on: July 07, 2018, 06:03:08 am »
Does the brightness slider work when you right-click on the power manager icon in the system tray (by the clock) ?
Offline Sgthawker
« Reply #7 on: July 07, 2018, 03:51:44 pm »
You know, I am not sure it is even there, I am not home now to look, but I will look in an hour or two and reply again.
Thanks for the time to assist!
Sent from my SM-G935V using Tapatalk
Offline Sgthawker
« Reply #8 on: July 07, 2018, 07:03:46 pm »
Okay, I do not see a brightness slider. I believe you mean via the battery icon when you right click? When I right click the battery icon I see:
Asustek Asus battery (my laptop)
Anywhere MX (my mouse)
Presentation mode
Power manager settings
In the Xfce power manager's 4 tabs I do not see a brightness slider at all. I do not see the brightness adjust bar at all as I did with no apparent response via PM 8 Respin as I had indicated in my first post in this thread.
Any more suggestions?
P.S. I see the battery icon is the Power Manager via the add new items to the panel.
« Last Edit: July 07, 2018, 07:07:16 pm by Sgthawker »
Offline maxlemont
« Reply #9 on: August 12, 2018, 04:29:03 pm »
Hi,
Do this, click menu (start menu) and search for and go to Power Manager. Under General tab, turn on handle display brightness keys.
Hope this helps.
Offline ogopogo
« Reply #10 on: August 14, 2018, 05:26:16 pm »
This worked for me.... Thanks Maxlemont
I do have another small issue though in regards to the screen brightness.  The brightness slider is almost all the way to the left when I go into suspend but when I bring my computer out of suspend  the screen brightness is always up full blast, but the slider is still in the same spot. When I go to move it slightly one way or the other it brings the brightness level back to a tolerable level.  Is this a quirk or something that can be fixed?
« Last Edit: August 14, 2018, 05:34:51 pm by ogopogo »
