Author Topic: Peppermint 7 uninvited xfce-4 Wiskermenu Plugin  (Read 1116 times)
Offline plumtreed
  • Been using Peppermint since it's start-up
  • Peppermint version(s): 10 64bit
« on: June 15, 2018, 02:51:14 pm »
I am using Peppermint7 and have somehow created a problem.......the 'Wisker-Menu' mouse has arrived in the lower,left hand corner....I didn't, intentionally, invite him.
How do I restore the original  peppermint set up?
Offline TonyBronze
  • Peppermintaholic
Re: Peppermint 7 uninvited xfce-4 Wiskermenu Plugin
« Reply #2 on: June 15, 2018, 03:14:34 pm »
Or if you just want to change the icon, right click on the Menu button, click on Properties, click on the Icon  and the "Select an Icon" box should pop up.  The default one is Peppermint-control-center
Edit: Make sure it says Select icon from: Menu Icons
« Last Edit: June 15, 2018, 03:20:15 pm by TonyBronze »
Offline plumtreed
« Reply #3 on: June 15, 2018, 03:59:19 pm »
see here:
https://forum.peppermintos.com/index.php/topic,5261.msg52747.html#msg52747
Thank you...........and the quick response!
........thanks also to TonyBronze............I just needed to get back to almost mormal;)
