Author Topic: laptop overheating?  (Read 2726 times)
Offline penrose1950
laptop overheating?
« on: July 23, 2014, 11:43:14 am »
hello i have got an Acer Aspire 5536 with 500 gb running Peppermint 5 and i know the weather is hot out but after about an hour and a half my laptop gets so hot it shuts down,i saw somewhere about changing the thermal paste but i have been quoted about 50 for it and even then it might not work,has any one got any ideas what i can do please?
i have removed the battery and i am running on mains.
thank you.
p.s. i have just ordered a 5 fan laptop cooler from ebay for 8.77
« Last Edit: July 23, 2014, 11:57:44 am by penrose1950 »
Re: laptop overheating?
« Reply #1 on: July 23, 2014, 01:38:35 pm »
I'm reading that Acer fixed the overheating issue in a BIOS update.
Bad news is you'll probably need to install Windows to apply the BIOS update.
Which BIOS vversion are you running, and what's the FULL model number ?
BTW, if you decide to update the BIOS, it's entirely AT YOUR OWN RISK
(get it wrong, or flash the wrong BIOS binary and you'll turn your PC into a doorstop)
Offline penrose1950
« Reply #2 on: July 24, 2014, 06:29:57 am »
my model number is M52265
BIOS Information
   Vendor: Phoenix Technologies LTD
   Version: V1.03
   Release Date: 02/27/2009
   Address: 0xE49E0
   Runtime Size: 112160 bytes
   ROM Size: 1024 kB
,i have just done a live chat to Acer and they are advising me to reinstall Vista which i really do not want to do as i love Peppermint 5
thank you.
« Last Edit: July 24, 2014, 06:55:40 am by penrose1950 »
« Reply #3 on: July 24, 2014, 10:04:43 am »
OK, this is not just a Linux problem, seems more like a design flaw as that laptop is known to overheat in Windows too. I'm reading a lot of people saying that opening up the sealed off air vents underneath helps .. see last response here:
http://www.tomshardware.co.uk/forum/59360-35-acer-aspire-5536-extreme-heat-issues
http://ubuntuforums.org/showthread.php?t=1854391
And that a BIOS update helps .. the latest BIOS appears to be 1.11 (dated 2009/11/19)
I won't actually "advise" these as there's risk involved .. it's up to you.
« Last Edit: July 24, 2014, 11:33:36 am by PCNetSpec, Reason: spelling »
Offline penrose1950
« Reply #4 on: July 24, 2014, 11:27:27 am »
ok thank you,i went to power manager and it was not turned on,when i clicked to turn it on i heard a noise so maybe that will help a little also i should get my laptop cooler with 5 fans tomorrow and maybe again that might drop the temp down enough so the laptop does not shutdown.
Offline rjm65
« Reply #5 on: July 24, 2014, 11:30:29 am »
I would also look above @pcnetspecs post and open up those sealed air vents as well, that will your 5 fan cooler blowing into the open vents will drop the temp down for you...   ;)
Robert
Peppermint 9 User
Gateway Solo 9300 Pro
IBM T40
Offline penrose1950
« Reply #6 on: July 24, 2014, 12:24:04 pm »
thank you i will try and take the back off and open the vents.
Offline rjm65
« Reply #7 on: July 24, 2014, 12:51:55 pm »
According to the guy in the post that opened his vents up with a knife he achieved and 27C drop in his overall temperature, he said his temp was 94C before and after was 67C, and I am sure with the fan pad under that blowing into the vent, you can achieve an even greater drop in temperature...   ;)
Robert
Peppermint 9 User
IBM T40
