Author Topic: Increase icon size on desktop [Solved]  (Read 2043 times)
Offline Fritz74
  • m, 46, Austria
« on: June 14, 2018, 01:24:48 pm »
Hello,
as said in the title, I would like to increase the size of the icons on the desktop.
Thanks in advance,
Fritz74
« Last Edit: June 15, 2018, 12:25:09 am by Fritz74 »
Offline mac
Re: Increase icon size on desktop
« Reply #1 on: June 14, 2018, 01:35:17 pm »
Right click on a blank space on the desktop, highlight Desktop and choose Icon Size.  You'll have three options: Smaller, Normal, Larger.  ;)
Reg. Linux User #432835
Offline Fritz74
  • m, 46, Austria
« Reply #2 on: June 14, 2018, 01:42:11 pm »
I know! But "larger" is too small. "Huge" would be perfect.
I like to put images with quotes and grocery lists on the desktop.
Maybe there is a setting in dconf-editor?
« Reply #3 on: June 14, 2018, 02:40:12 pm »
It's the "use-desktop-grid" function of nemo that disables manual resizing of icons (because it wouldn't be able to snap icons of differing sizes to a grid)
Fire up dconf-editor, and go to:-
org > nemo > desktop
remove the tick from "use-desktop-grid"
OR
simply run:
gsettings set org.nemo.desktop use-desktop-grid false
Now if you right-click on a desktop icon you should have an option called "Resize Icon" .. select that and you can drag the icon to any size you like by dragging any of the 4 handles that appeared on that icon.
(there should also be a "Restore Icons Original Size" item)
If you want TONS of text under the icons, you may also need to adjust this key in dconf-editor
org > nemo > desktop > text-elipsis-limit
« Last Edit: July 01, 2018, 08:38:37 am by PCNetSpec »
Offline Fritz74
  • m, 46, Austria
« Reply #4 on: June 14, 2018, 11:26:15 pm »
Perfect. Thank you!  :)
« Reply #5 on: June 15, 2018, 12:24:04 am »
Hi Fritz74,
Glad to see it is resolved for you.
Would you please go back to your original post and click modify and put [Solved] at the end of the subject line.  This will help other users know there is a solution they can try.
