Author Topic: [SOLVED] 3/4 Netbookscreen blank  (Read 1952 times)
Offline dro3m
  • StormTrooper
  • Peppermint version(s): Peppermint OS 8
« on: June 13, 2018, 09:27:40 am »
   Hi, I have a Toshiba NB205. Netbook I had Peppermint OS 8 freshly installed and updated. My problem is that every time I boot up, 3/4 of the login screen is missing with red, green and blue dots on top and it will stay there after I login. I can move my mouse cursor into the blank area  and see it just fine. I can only remove the problem by closing the netbook lid, let it sleep and awake it. I had the same problem in Ubuntu Mate. But this problem does not happen in Bodhi Linux, Linux Mint, Linux Lite, and Lubuntu. What cause this problem, and how can I fix it? Any thing well do.
« Last Edit: June 13, 2018, 02:23:51 pm by dro3m »
dro3m
My signature needs more eye candy, but the admins took out all the fun stuff.
Offline mac
Welcome Aboard, dro3m!    ;)
You can start by checking for additional drivers.  Navigate: Menu > Preferences > Peppermint Settings Panel and choose Hardware on the left side menu.  Open "Additional Drivers" and let it search (may take some time).  If there is one you can install it from there.
Please post the results of
Reg. Linux User #432835
Offline dro3m
  • StormTrooper
There are no drivers to install.
Results:
System:    Host: TOSHIBA-NB205 Kernel: 4.13.0-45-generic i686 (32 bit)
Machine:   System: TOSHIBA product: TOSHIBA NB205 v: PLL20U-00Q01D
           Mobo: TOSHIBA model: KAVAA v: 1.00
           Bios: TOSHIBA v: V1.70 date: 09/30/2009
CPU:       Single core Intel Atom N280 (-HT-) cache: 512 KB
           clock speeds: max: 1667 MHz 1: 1022 MHz
           2: 1009 MHz
Graphics:  Card: Intel Mobile 945GSE Express Integrated Graphics Controller
           Display Server: X.Org 1.19.5 drivers: intel (unloaded: fbdev,vesa)
           Resolution: 1024x600@60.00hz
           GLX Renderer: Mesa DRI Intel 945GME x86/MMX/SSE2
           GLX Version: 1.4 Mesa 17.0.2
Audio:     Card Intel NM10/ICH7 Family High Definition Audio Controller
           Sound: ALSA v: k4.13.0-45-generic
Network:   Card-1: Qualcomm Atheros AR9285 Wireless Network Adapter (PCI-Express)
           driver: ath9k
           Card-2: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet controller
           driver: r8169
           IF: enp4s0 state: down mac: <filter>
Drives:    HDD Total Size: 128.0GB (21.7% used)
           ID-1: /dev/sda model: CRUCIAL_CT128M22 size: 128.0GB
           ID-1: / size: 59G used: 4.8G (9%) fs: ext4 dev: /dev/sda1
           ID-2: /home size: 55G used: 18G (34%) fs: ext4 dev: /dev/sda3
           ID-3: swap-1 size: 4.29GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors:   System Temperatures: cpu: 48.0C mobo: N/A
Info:      Processes: 151 Uptime: 1:17 Memory: 275.6/2003.3MB
dro3m
Offline dro3m
  • StormTrooper
Ah, thank you. It worked perfectly. I would suggest adding that bit of code to the next major update to add more support. Well done, thank you.  :)
dro3m
Peppermint 9 will be the next major update (due out soon), and I gather this isn't necessary on the 18.04 code base :)
Offline 00ninja
  • Peppermint version(s): P8 R2 (x64), P9 (x64)
I don't know how different a Toshiba NB255 is from your 205 (they should be the same hardware wise?), but I had great results installing with both P8 and the Respin2 versions.....Other than the common issues seen with 1024x600 max resolution screens and the occasional menu being too large to see all the options or buttons at the bottom of the menu.
But definately good to bookmark this fix, thanks PCNetSpec!
Offline dro3m
  • StormTrooper
Is it already there? Or does it have something like it?
dro3m
Re: [SOLVED] 3/4 Netbookscreen blank
« Reply #8 on: June 13, 2018, 03:20:47 pm »
No, I gather the fix simply isn't necessary on the 18.04 code base and was a bug specific to the 16.04 code base.
I won't know for sure until someone with a netbook confirms it, but the original bug report suggests the bug isn't present in 18.04
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1724639
« Last Edit: June 13, 2018, 03:23:11 pm by PCNetSpec »
Offline dro3m
  • StormTrooper
« Reply #9 on: June 13, 2018, 04:23:50 pm »
Um, me I had Lubuntu 18.04 on my netbook and I had no issues, so I think your clear.
dro3m
« Reply #10 on: June 13, 2018, 04:49:05 pm »
Cheers for the confirmation :)
Offline dro3m
  • StormTrooper
« Reply #11 on: June 13, 2018, 07:10:01 pm »
You want me to be a beta/alpha tester? I only have 32-bit computers at the moment (most likely for a while) as my main rig died a few months ago. R.I.P  Stormtrooper 1.0
dro3m
« Reply #12 on: June 14, 2018, 01:43:35 pm »
Sorry, it's a closed beta test.
Offline dro3m
  • StormTrooper
« Reply #13 on: June 14, 2018, 07:42:57 pm »
Awww man, too bad.  :(
dro3m
