Author Topic: How do you customize the desktop and 'theme' of peppermints interface ? (SOLVED)  (Read 11119 times)
Offline iamesperambient
  • a totally awesome dude
thanks sure i will give it a try it looks good. how do i remove docky and not have it autostart? just sudo-apt get remove docky?
http://iamesper.bandcamp.com
boring drone music from NJ
ok yep sudo apt-get remove docky got rid of it. how do i get plank sudo apt-get install plank?
To remove docky . close docky, then run:
sudo apt remove docky
Installing plank requires the addition of a PPA, so run these commands in sequence:
sudo add-apt-repository ppa:ricotz/dockyand hit enter when prompted .. then
sudo apt updatethen
sudo apt install plank
To set plank to autostart run:
cp -v /usr/share/applications/plank.desktop ~/.config/autostart/plank.desktop
« Last Edit: July 23, 2014, 04:57:07 pm by PCNetSpec »
got it a lot more simple than docky but no bigs really like docky has i wish it was more able to  customize as far as size goes but it works for me.
Well ya takes your pick, or ya tries cairo
But I'm off to bed for tonight.
yeah maybe ill try that another time next time your own if you can help me try to install cairo ill see which one i like the best so far this is fine i just wished i could remove the back outline around it but not a huge deal.
HI  iamesperambient
I would go for Cairo Dock (although some night disagree) but so long as your system has the power I find it the easiest to use and by far the most configurable, it also has all the eye candy you're looking for,
 I know Mark (our resident guru) considers it a resource hog but to be honest I've never found that and I don't have a particularly powerful PC
Anyway the choice is yours no harm giving Cairo Dock a try and if you don't like it for any reason you can always remove it and never listen to me again :)
as far as widgets are concerned there's an application called Screenlets which I suppose are a kind of widget you'll find it in the repos which allow you to add small applications to your desktop like a clock or weather app etc but to be honest I didn't find any of them worked very well
Anyway Good luck
« Last Edit: July 24, 2014, 01:00:25 am by emegra »
Black outline ? .. have you disabled the compositor (desktop efffects) in the Peppermint Control Centre .. or is this not Peppermint 5 ?
Pretty much all dock bars require a compositor for transparency
I haven't disabled anythign (at least not on purpose) i just put in the codes you gave me.  but now it has a black outline and when i try to go to settings it won't allow me to
change anything.
and yes im using peppermint 5
i removed docky and installed ciaro dock but that also does not load when i reboot.  I think out of all of them i like docky the best.
now sure how to get docky back to the original state it was in now.
Autostarting at bootup should be easily fixable .. for both cairo-dock and docky.
It's whether they come back after resume from suspend that's the problem (at least for docky, not sure about cairo-dock).
change anything.
What settings ?
Plank doesn't have a settings GUI  :-\
The problem with Docky is being caused by another version (3.0) being in the plank PPA .. so we need to remove that PPA
Run:
sudo apt-get purge dockythe
sudo apt autoremovethen
sudo apt install ppa-purgethen
sudo ppa-purge ppa:ricotz/dockythen when that's done
sudo apt updatethen
sudo apt install docky
« Last Edit: July 24, 2014, 03:57:43 pm by VinDSL »
i installed ciaro dock it seems to be working with out any bugs and i figured out how to customize it :D
