Author Topic: Oygen Shadow external drive reads but won't let me add files  (Read 2997 times)
Offline iamesperambient
  • a totally awesome dude
So i have 2 portable drives my 2nd one a oygen shadow will read on linux and allow me to drag the files off of it (which is also great) but will not allow me to add new files on to it.
Does anyone know why?
http://iamesper.bandcamp.com
boring drone music from NJ
Re: Oygen Shadow external drive reads but won't let me add files
« Reply #1 on: July 23, 2014, 10:44:54 am »
At a guess I'd say it's probably got some kind of file system corruption, so the system flags it as "dirty" and remounts it read-only (so further damage can't be caused).
WIth the drive plugged in, and so you can access it in file manager.
What's the output from:
mount
« Reply #2 on: July 23, 2014, 11:20:07 am »
 mount
/dev/sda1 on / type ext4 (rw,errors=remount-ro)
proc on /proc type proc (rw,noexec,nosuid,nodev)
sysfs on /sys type sysfs (rw,noexec,nosuid,nodev)
none on /sys/fs/cgroup type tmpfs (rw)
none on /sys/fs/fuse/connections type fusectl (rw)
none on /sys/kernel/debug type debugfs (rw)
none on /sys/kernel/security type securityfs (rw)
udev on /dev type devtmpfs (rw,mode=0755)
devpts on /dev/pts type devpts (rw,noexec,nosuid,gid=5,mode=0620)
tmpfs on /run type tmpfs (rw,noexec,nosuid,size=10%,mode=0755)
none on /run/lock type tmpfs (rw,noexec,nosuid,nodev,size=5242880)
none on /run/shm type tmpfs (rw,nosuid,nodev)
none on /run/user type tmpfs (rw,noexec,nosuid,nodev,size=104857600,mode=0755)
none on /sys/fs/pstore type pstore (rw)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,noexec,nosuid,nodev)
systemd on /sys/fs/cgroup/systemd type cgroup (rw,noexec,nosuid,nodev,none,name=systemd)
gvfsd-fuse on /run/user/1001/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,user=iamesper)
/dev/sdb2 on /media/iamesper/Justin's HD type hfsplus (ro,nosuid,nodev,uhelper=udisks2)
hope its not currupt i have a lot of files on this thing :/
« Reply #3 on: July 23, 2014, 11:25:17 am »
Hold on .. this is an hfs+ drive .. is it from a Mac ?
« Reply #4 on: July 23, 2014, 11:26:57 am »
yeah this i used to use on my old mac, it seems to read on here.
« Reply #5 on: July 23, 2014, 11:37:41 am »
Try this:
sudo apt install hfsplus hfsutils hfsprogsthen unplug the drve .. wait 10 seconds .. replug the drive .. post the output from:
mount
« Reply #6 on: July 23, 2014, 11:45:21 am »
ok i will try this now
« Reply #7 on: July 23, 2014, 11:52:39 am »
mount
this is what returned
« Reply #8 on: July 23, 2014, 12:09:51 pm »
Unplug the drive .. wait 10 seconds .. replug the drive .. post the output from:
dmesg | tail -n 35
« Reply #9 on: July 23, 2014, 12:12:47 pm »
iamesper@justin-Latitude-D630 ~ $ dmesg | tail -n 35
[13146.300472] sd 8:0:0:0: [sdb] Sense not available.
[13146.300500] sd 8:0:0:0: [sdb] No Caching mode page found
[13146.300503] sd 8:0:0:0: [sdb] Assuming drive cache: write through
[13146.300508] sd 8:0:0:0: [sdb] Attached SCSI disk
[13146.572303] usb 2-1: new high-speed USB device number 12 using ehci-pci
[13146.734739] usb 2-1: New USB device found, idVendor=174c, idProduct=5106
[13146.734751] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[13146.734759] usb 2-1: Product: AS2105
[13146.734767] usb 2-1: Manufacturer: ASMedia
[13146.734774] usb 2-1: SerialNumber:            X2IFSA5SS
[13146.735395] usb-storage 2-1:1.0: USB Mass Storage device detected
[13146.736446] scsi9 : usb-storage 2-1:1.0
[13146.893394] usb 2-1: USB disconnect, device number 12
[13158.288351] usb 2-1: new high-speed USB device number 13 using ehci-pci
[13159.273679] usb 2-1: New USB device found, idVendor=174c, idProduct=5106
[13159.273692] usb 2-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[13159.273700] usb 2-1: Product: AS2105
[13159.273707] usb 2-1: Manufacturer: ASMedia
[13159.273714] usb 2-1: SerialNumber:            X2IFSA5SS
[13159.274419] usb-storage 2-1:1.0: USB Mass Storage device detected
[13159.276150] scsi10 : usb-storage 2-1:1.0
[13160.279517] scsi 10:0:0:0: Direct-Access     TOSHIBA  MQ01ABD050       AX00 PQ: 0 ANSI: 5
[13160.280799] sd 10:0:0:0: Attached scsi generic sg2 type 0
[13160.290128] sd 10:0:0:0: [sdb] 976773168 512-byte logical blocks: (500 GB/465 GiB)
[13160.291552] sd 10:0:0:0: [sdb] Write Protect is off
[13160.291561] sd 10:0:0:0: [sdb] Mode Sense: 23 00 00 00
[13160.292534] sd 10:0:0:0: [sdb] No Caching mode page found
[13160.292541] sd 10:0:0:0: [sdb] Assuming drive cache: write through
[13160.296455] sd 10:0:0:0: [sdb] No Caching mode page found
[13160.296463] sd 10:0:0:0: [sdb] Assuming drive cache: write through
[13160.427488]  sdb: sdb1 sdb2
[13160.439714] sd 10:0:0:0: [sdb] No Caching mode page found
[13160.439729] sd 10:0:0:0: [sdb] Assuming drive cache: write through
[13160.439740] sd 10:0:0:0: [sdb] Attached SCSI disk
[13161.116558] hfsplus: write access to a journaled filesystem is not supported, use the force option at your own risk, mounting read-only.
doesnt seem good :/
« Reply #10 on: July 23, 2014, 12:17:06 pm »
would this be safe to use ? as of now im just using it with audacious to play my music directly of the HD
(i have all my files backed on this drive as well as a WD passport both are not working fully at the moment :/)
« Reply #11 on: July 23, 2014, 01:55:33 pm »
The problem is the journalled hfs+ file system.
We can force it into read-write from the command line, but it's never going to be automagic.
Do you still have acccess to a Mac with an OS before 10.9 ? .. if so we can turn off journalling, then it will mount read-write.
If not, and there's not too much on it .. again you'd need to move the stuff to another drive .. format the drive as say NTFS .. copy the stuff back
