Author Topic: iphone 5SE connection - SOLVED  (Read 729 times)
Offline s2
« on: June 10, 2018, 05:49:19 am »
good morning.
i'm using Peppermint 8 64bit.
my iphone will not connect to my laptop.
plugged into usb port i get nothing.
need help.
« Last Edit: July 06, 2018, 08:02:40 am by s2 »
Re: iphone 5SE connection
« Reply #1 on: June 10, 2018, 06:06:50 am »
Plug it in, make sure you hit "Allow" on the phone screen, and mount it. (click on it on your list of devices in the File Manager to mount it) You'll get a blank window, which is what I'm assuming you're getting now. Umount it by clicking on the eject symbol next to the device but don't unplug it. Mount it again and you should see your DCIM folder, which is all you'll have access to.
I know, this sounds weird, but I have the same model of phone and it works.
Offline s2
Re: iphone 5SE connection (solved)
« Reply #2 on: June 10, 2018, 11:37:55 pm »
thanks much for the help.
i did nothing to fix the issue.
it just started working.
may be a cable problem.
« Reply #3 on: June 10, 2018, 11:56:27 pm »
I don't know, they're hit or miss on working with Linux.
