Author Topic: Dropbox will not install (SOLVED)  (Read 2073 times)
Offline iamesperambient
  • a totally awesome dude
« on: July 22, 2014, 08:28:38 pm »
tried to install drop box and it stops at 100 % but will not close out or fully install.
« Last Edit: July 22, 2014, 10:01:51 pm by PCNetSpec »
http://iamesper.bandcamp.com
boring drone music from NJ
  • Peppermint version(s): Peppermint 7 Respin (64bit)
Re: Dropbox will not install
« Reply #1 on: July 22, 2014, 08:52:26 pm »
I think this was fixed in an update (unless it's broken again)
Run a full system update by running these 3 commands in sequence:
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
Now REBOOT.
Once rebooted, try running dropbox again from the menu.
« Reply #2 on: July 22, 2014, 09:01:43 pm »
terminal actually closed itself out on the 2nd command :/
also read on here someone did a recent upgrade and OS would not
boot back up so i'm a bit worried to try it again now
« Reply #3 on: July 22, 2014, 09:19:08 pm »
try again
If someone else had problems, it's a one off .. I (and millions of others) update all the time without issue.
« Reply #4 on: July 22, 2014, 09:29:30 pm »
ok i will give it a try again and let you know!
« Reply #5 on: July 22, 2014, 09:33:30 pm »
If you're going to try it now (whilst I'm about), hurry up because I'm off to bed in a sec .. half past 2 here.
« Reply #6 on: July 22, 2014, 09:34:30 pm »
i am im doing it right now terminal is doing its thing ....hopefully this works
« Reply #7 on: July 22, 2014, 09:39:03 pm »
how long does this update usually take?
« Reply #8 on: July 22, 2014, 09:44:43 pm »
Not very .. ten minutes (ish)
This is NOT Windows ;)
« Reply #9 on: July 22, 2014, 09:46:09 pm »
ok hopefully it will be done soon still going...
« Reply #10 on: July 22, 2014, 09:47:48 pm »
Don't worry .. it's not going to take hours like Windows ;)
« Reply #11 on: July 22, 2014, 09:49:01 pm »
ok its done going to reboot crossing my fingers i will be back in a minute
« Reply #12 on: July 22, 2014, 09:51:46 pm »
ok everything booted up so thats GREAT. trying to download dropbox again lets see
Thanks it worked!!!!!!
« Last Edit: July 22, 2014, 10:02:10 pm by PCNetSpec »
Re: Dropbox will not install (SOLVED)
« Reply #13 on: July 22, 2014, 10:02:52 pm »
No problem .. I'm off to bed, catch you later.
Offline 10i
  • Peppermint Enthusiast
    • My Peppermint Blog
  • Peppermint version(s): Peppermint 6 - 32 bit
« Reply #14 on: July 28, 2014, 03:34:15 pm »
Just wanted to say thanks.
Had the same issue, and your solution worked well :)
Running Peppermint 6 - 32 bit on my Lenovo s10e netbook
