Author Topic: Solve linux freeze shutdown problem (freeze on shutdown)  (Read 2644 times)
Offline DARKBOW923
  • All linux problem have solutions.
  • Peppermint version(s): Peppermint 7 64 bit :D
« on: June 03, 2018, 02:42:33 pm »
Hi all, first, sorry for my bad english, but i need to put this tutorial here.
Today i found a solution to my problem, my problem was my linux machine freeze on shutdown, not take's too long to shutdown.
Okay, only if your linux machine freeze on shutdown you can make this tutorial, if your problem is other than i expose on this tutorial, don't follow this steps
Okay, i tested this method in my new linux mint, but i see that worked for me on peppermint 8 machine, so here are the requeriments:
Minimum  knowledge on terminal emulator.
Distro based on ubuntu/debian
A PC with this problem.
Minimum knowledge of GRUB.
Okay, this steps are too easy to make, just type on a terminal:
sudo nano /etc/default/grub
Then navigate to this line:
Modify this line like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash acpi=force"
Finally, just save and close, then run this command in your terminal:
sudo update-grub
FInal step: Restart your machine.
I say an last thin, this worked for me in linux mint 18 and peppermint 8 im pretty sure that maybe work's for you..
Bye!
Now with new machine! Medion AKOYA intel core i3 7100 3mb caché 7th gen, 4GB RAM DDR4 Intel HD Graphics 630 1TB HDD space.
Re: Solve linux freeze shutdown problem (freeze on shutdown)
« Reply #1 on: June 03, 2018, 02:44:29 pm »
Thanks DARKBOW923 :)
