Author Topic: Linux firmware update to 1.157.17 fails  (Read 2069 times)
Offline kjl
  • Peppermint version(s): 8.0
« on: May 06, 2018, 06:32:47 pm »
Updating firmware 1.157.15 to 1.157.17 fails with error; unexpected end of file or stream.
Other software-packages can update-install with no issues using package  manager,
terminal.
The firmware update fails, tries recover but just hangs on recovery until manually
closed.
Also having network issues on a 100mbps connection, google chrome failed to connect
on any  page with  o snap.
Don't know if the internet connection issue is causing the update issue, but not an issue on
win10 connecting through the same device.
Re: Linux firmware update to 1.157.17 fails
« Reply #1 on: May 06, 2018, 08:08:26 pm »
Hi kjl, how's it going  :)?  Welcome to the Peppermint Forum.  It's very nice to meet you  ;).  Could you please let us have a little more information about your computer?   Open up a terminal window with the following keystrokes:
Ctrl+Alt+t
Enter, (Copy & Paste) the following command into the terminal window and hit enter.  Post back the output to the forum:
Note:  Please remember to encapsulate terminal outputs with the Insert, Code # function.  For extra long outputs, please use the Spoiler, Sp function.  It preserves the original format of the output.  This makes it easier for future visitors to relate to their own issues.  These functions are found in the forum editor, above the,  :-[ Embarrassed and  the :'( Cry emoticon respectively - many thanks  :).
Offline kjl
« Reply #2 on: May 06, 2018, 08:27:28 pm »
As per the requsted output;
kenneth@kenneth-MS-6728 ~ $ inxi -Fz
System:    Host: kenneth-MS-6728 Kernel: 4.13.0-39-generic i686 (32 bit)
Machine:   Mobo: MICRO-STAR model: MS-6728 v: 100
           Bios: American Megatrends v: V2.5 date: 09/29/2004
CPU:       Single core Intel Pentium 4 (-HT-) cache: 1024 KB
           clock speeds: max: 2800 MHz 1: 2800 MHz 2: 2800 MHz
Graphics:  Card: Advanced Micro Devices [AMD/ATI] RV280 [Radeon 9200 PRO]
           Display Server: X.Org 1.19.5 drivers: ati,radeon (unloaded: fbdev,vesa)
           Resolution: 1024x768@60.00hz
           GLX Renderer: Mesa DRI R200 (RV280 5960) x86/MMX/SSE2 DRI2
           GLX Version: 1.3 Mesa 17.0.2
Audio:     Card Intel 82801EB/ER (ICH5/ICH5R) AC'97 Audio Controller
           driver: snd_intel8x0
           Sound: Advanced Linux Sound Architecture v: k4.13.0-39-generic
Network:   Card: Intel 82562EZ 10/100 Ethernet Controller driver: e100
           IF: enp2s8 state: up speed: 100 Mbps duplex: full mac: <filter>
Drives:    HDD Total Size: 40.0GB (17.2% used)
           ID-1: /dev/sda model: HDS728040PLA320 size: 40.0GB
Partition: ID-1: / size: 35G used: 4.5G (14%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 2.15GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   None detected - is lm-sensors installed and configured?
Info:      Processes: 143 Uptime: 23 min Memory: 554.1/2012.2MB
« Last Edit: May 08, 2018, 12:31:46 am by AndyInMokum, Reason: Encapsulating output with [code] »
Offline mac
« Reply #3 on: May 06, 2018, 08:30:12 pm »
What happens when you run in your terminal...
sudo apt install linux-firmware
Reg. Linux User #432835
Offline kjl
« Reply #4 on: May 06, 2018, 10:07:56 pm »
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
  gir1.2-networkmanager-1.0 gir1.2-nma-1.0 libido3-0.1-0
Use 'sudo apt autoremove' to remove them.
The following packages will be upgraded:
  linux-firmware
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/45.5 MB of archives.
After this operation, 87.0 kB of additional disk space will be used.
(Reading database ... 334588 files and directories currently installed.)
Preparing to unpack .../linux-firmware_1.157.17_all.deb ...
Unpacking linux-firmware (1.157.17) over (1.157.15) ...
dpkg-deb (subprocess): decompressing archive member: lzma error: compressed data is corrupt
dpkg-deb: error: subprocess <decompress> returned error exit status 2
dpkg: error processing archive /var/cache/apt/archives/linux-firmware_1.157.17_all.deb (--unpack):
 cannot copy extracted data for './lib/firmware/ql2322_fw.bin' to '/lib/firmware/ql2322_fw.bin.dpkg-new': unexpected end of file or stream
update-initramfs: Generating /boot/initrd.img-4.13.0-39-generic
update-initramfs: Generating /boot/initrd.img-4.13.0-32-generic
Progress: [ 33%] [######################........................
« Last Edit: May 08, 2018, 12:32:56 am by AndyInMokum, Reason: Encapsulating output with [code] »
Offline kjl
« Reply #5 on: May 06, 2018, 10:12:33 pm »
Sorry on previous post did not let the command finish, completed results;
  linux-firmware
E: Sub-process /usr/bin/dpkg returned an error code (1)
« Last Edit: May 08, 2018, 12:33:35 am by AndyInMokum, Reason: Encapsulating output with [code] »
Offline mac
« Reply #6 on: May 06, 2018, 10:21:55 pm »
Try this...
sudo dpkg --configure -a
Then...
sudo apt update && sudo apt upgrade
Then...
sudo dpkg --clear-avail
Then again...
Try installing linux-firmware again
Offline kjl
« Reply #7 on: May 06, 2018, 11:09:55 pm »
Same results
et:1 http://security.ubuntu.com/ubuntu xenial-security InRelease [107 kB]
Hit:2 http://us.archive.ubuntu.com/ubuntu xenial InRelease
Get:3 http://us.archive.ubuntu.com/ubuntu xenial-updates InRelease [109 kB]
Hit:4 http://ppa.launchpad.net/peppermintos/p8-release/ubuntu xenial InRelease
Hit:5 http://ppa.launchpad.net/peppermintos/p8-release-llvm-toolchain-3.9/ubuntu xenial InRelease
Get:6 http://us.archive.ubuntu.com/ubuntu xenial-backports InRelease [107 kB]
Hit:7 http://ppa.launchpad.net/peppermintos/p8-release-llvm-toolchain-4.0/ubuntu xenial InRelease
Hit:8 http://ppa.launchpad.net/peppermintos/p8-respin/ubuntu xenial InRelease
Fetched 323 kB in 2s (150 kB/s)
1 package can be upgraded. Run 'apt list --upgradable' to see it.
Calculating upgrade... Done
  linux-firmware
Do you want to continue? [Y/n] y
(Reading database ... 334665 files and directories currently installed.)
kenneth@kenneth-MS-6728 ~ $ sudo dpkg --clear-avail
dpkg: error: need an action option
Type dpkg --help for help about installing and deinstalling packages
Use 'apt' or 'aptitude' for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked
  • produce a lot of output - pipe it through 'less' or 'more' !
kenneth@kenneth-MS-6728 ~ $ sudo apt update && sudo apt upgrade
Get:1 http://security.ubuntu.com/ubuntu xenial-security InRelease [107 kB]
Fetched 323 kB in 1s (162 kB/s)
  linux-firmware
The fail state is always at 33% completed.
« Last Edit: May 07, 2018, 07:59:10 am by mac »
Offline mac
« Reply #8 on: May 07, 2018, 08:36:40 am »
You might Try...
sudo apt-get -f install
BTW how long do you let it stand at 33% before closing?
« Last Edit: May 07, 2018, 08:43:05 am by mac »
Offline kjl
« Reply #9 on: May 07, 2018, 09:14:10 pm »
Tried to run clonezilla as thought might be a disk issue, now getting out of memory on startup.
Going to have to put this on the backburner for now until later in the week or weekend.
Will post on results but think I need a clean install.
Online PCNetSpec
« Reply #10 on: May 07, 2018, 09:14:25 pm »
You seem to have a corrupt package in the package cache.
Try clearing the package cache and reinstalling linux-firmware
sudo apt-get clean
sudo apt-get install --reinstall linux-firmware
The first of those commands will also free up disk space .. run it from a console if necessary.
« Last Edit: May 07, 2018, 09:19:39 pm by PCNetSpec »
Offline kjl
« Reply #11 on: May 07, 2018, 09:17:26 pm »
The 33% ran about 10 to 15 minutes, then the error could not complete.
Most times I just let it run waiting for the output.
Online PCNetSpec
« Reply #12 on: May 07, 2018, 09:21:05 pm »
Try those commands.
« Reply #13 on: May 08, 2018, 12:38:56 am »
Hi kjl, how's it going :) ?  I see you're having trouble encapsulating terminal outputs.  Try this the next time  :).  After you've pasted the output to the forum editor.  Highlight the output by placing the mouse cursor at the beginning of the output.  Depress the left mouse button and hold.  Drag the cursor to the end of the output and release the left mouse button.  The output will now be highlighted.  In the forum editing options, not your keyboard option, select the # and left click on it.  This function is located above the  :-[ (Embarrassed) emoticon.   Your terminal output will now be encapsulated with the Code function.  I've done this for you this time.  I hope this helps  ;).
Offline kjl
« Reply #14 on: May 08, 2018, 06:55:54 pm »
After running recovery a few times, managed to get to the desktop with no errors.
Ran both commands in terminal, first one had no output, second one;
0 upgraded, 0 newly installed, 0 to remove and 7 not upgraded.
« Last Edit: May 08, 2018, 09:01:50 pm by AndyInMokum, Reason: Encapsulating output with [code] »
