Author Topic: Ethernet Works / Wifi doesn't since today's updates [SOLVED]  (Read 3213 times)
Re: Ethernet Works / Wifi doesn't since today's updates
« Reply #15 on: April 24, 2018, 01:18:21 pm »
I'll negate that as the ethernet connection is resolving just fine... or does Wifi access any differently?
No it's the same, but you could have had different DNS servers set in your wired/wireless network profiles ;)
Anyway, have you tried deleting your current wireless network profile and recreating it ?
It would also be handy if you could try the adpater on another PC .. to rule in/out it having failed.
« Reply #16 on: April 24, 2018, 02:07:15 pm »
I have never messed with DNS servers, that I recollect. It's been advised, but I have always walked away from that as it's handled by the router in other half's domain of expertise. Currently on my machine, both the wired and wireless connections are Automatic DHCP, and thus IPV4 settings are blank. When I select "Connection Information" I note that the IPV4 address is different for Wired vs wireless, but all the rest of the fields are the same.  I've got several things going on currently and don't need any network recreating hassle today...
I do however have a laptop sitting in the living room that my Mom sent to me to triage, but I'm sure it's infected beyond all get out... I released all other devices to the recycling universe...
Thanks for helping me narrow it down, I'll report back later today or in the next few days after Mom's laptop is cleared...
« Last Edit: April 24, 2018, 02:10:56 pm by spence »
« Reply #17 on: April 24, 2018, 04:44:05 pm »
Operating from the LiveUSB environment on Mom's Toshiba... with her internal Wifi... will need to ponder  installing all  the realtec drivers and how to switch from her internal wifi to  the dongle's... back in a wee bit again...
« Reply #18 on: April 24, 2018, 05:52:26 pm »
Okay, hubby offered to install the dongle in his Win10 machine... He was able to get it installed and working lickety-split... pages that took forever on my machine loaded instantly for him...
So back to square one...
« Reply #19 on: April 24, 2018, 06:24:16 pm »
Okay, you're going to need to try deleting your wireless network profile in networkmanager, then try setting up wireless again.
and if that doesn't work, you'll have to go through the log at
xed /var/log/apt/history.logand tell us what got updated today .. should be near the bottom of that file.
« Reply #20 on: April 24, 2018, 06:30:35 pm »
will need to step away from this for today... family melting down as niece swirls deeper into addiction... all prayers for clarity and healing accepted with grace... :(
« Reply #21 on: April 24, 2018, 06:36:36 pm »
Okay good luck with your family crisis spence .. all the best my friend :)
We can come back to this once you've dealt with the much more important stuff.
Re: Ethernet Works / Wifi doesn't since today's updates[SOLVED]
« Reply #22 on: April 28, 2018, 01:58:46 pm »
Having a family member lost to addiction is a never ending thing... thanks to all who offered support online or mentally. :'(
My Issue seems to have disappeared after I unticked the box which says:
Require IPV4 addressing for this connection to complete
I'll leave it for a few days to see then marks as solved
« Last Edit: April 29, 2018, 12:26:41 pm by spence »
