Author Topic: Subject: Realtek RTL8812BU driver required. (SOLVED)  (Read 16493 times)
Offline ggsinclair
« on: April 12, 2018, 12:33:38 am »
This topic has been split from this earlier one:
https://forum.peppermintos.com/index.php/topic,5018.0.html
PM sent with link to this new topic.
[END EDIT]
Hi.
This is really useful information, however, when I run the commands I get the following error.  Am I doing something stupid? (wouldnt be the first time!!)
Thanks.
Gordon
gordon@gordon-imedia-S2110 ~/RTL8812AU $ sudo dkms add -m 8812au -v 4.2.2
Creating symlink /var/lib/dkms/8812au/4.2.2/source ->
                 /usr/src/8812au-4.2.2
DKMS: add completed.
gordon@gordon-imedia-S2110 ~/RTL8812AU $ sudo dkms build -m 8812au -v 4.2.2
Kernel preparation unnecessary for this kernel.  Skipping...
Building module:
cleaning build area....
'make' all KVER=4.13.0-38-generic.....................................................
DKMS: build completed.
gordon@gordon-imedia-S2110 ~/RTL8812AU $ sudo modprobe -r 8812au
modprobe: FATAL: Module 8812au not found.
gordon@gordon-imedia-S2110 ~/RTL8812AU $ sudo modprobe 8812au
modprobe: FATAL: Module 8812au not found in directory /lib/modules/4.13.0-38-generic
« Last Edit: April 12, 2018, 11:54:36 pm by ggsinclair »
Re: Realtek RTL8812BU driver required.
« Reply #1 on: April 12, 2018, 04:28:05 am »
You seem to have missed out the command
sudo dkms install -m 8812au -v 4.2.2
Offline ggsinclair
« Reply #2 on: April 12, 2018, 09:19:12 am »
Hi.
You were right.  Thank you.
Installed ok.  Still not finding the USB dongle.
Am thinking possibly as its USB3 and my box only has USB2.
Have tried it on other distros and they dont recognise it either. Works ok on Windoze.
First time I have been unable to install something in years.  Frustrating!
Thanks again.
Gordon
« Reply #3 on: April 12, 2018, 09:24:49 am »
It's unlikely anything to do with USB3 .. with the USB wireless adapter plugged in, what's the output from:
lsusband
sudo lshw -C networkand
rfkill listand
iwconfig
Offline ggsinclair
« Reply #4 on: April 12, 2018, 09:48:43 am »
Hi.
Thanks.
Output as follows:
gordon@gordon-imedia-S2110 ~ $ lsusb
Bus 003 Device 003: ID 0bda:b812 Realtek Semiconductor Corp.
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 0e8f:00a7 GreenAsia Inc.
Bus 004 Device 002: ID 04f3:0103 Elan Microelectronics Corp. ActiveJet K-2024 Multimedia Keyboard
gordon@gordon-imedia-S2110 ~ $ sudo lshw -C network
  *-network
       physical id: 0
       bus info: pci@0000:04:00.0
       logical name: enp4s0
       version: 06
       serial: 74:27:ea:24:8c:f5
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=half firmware=rtl8168e-3_0.0.4 03/27/12 latency=0 link=no multicast=yes port=MII speed=10Mbit/s
       resources: irq:24 ioport:e000(size=256) memory:d0004000-d0004fff memory:d0000000-d0003fff
gordon@gordon-imedia-S2110 ~ $ rfkill list
gordon@gordon-imedia-S2110 ~ $ iwconfig
enp4s0    no wireless extensions.
Thanks.
Gordon
« Last Edit: April 12, 2018, 11:31:11 am by AndyInMokum »
« Reply #5 on: April 12, 2018, 10:20:45 am »
It looks like you're trying to install the wrong driver for that adapter.
Your adapter is based on the Realtek RTL8812BU chipset, not the RTL8812AU chipset .. I'll see what I can find
« Last Edit: April 12, 2018, 10:26:07 am by PCNetSpec »
« Reply #6 on: April 12, 2018, 10:45:53 am »
Okay, it looks like you require the 8822bu driver (which contains the IDvendor:IDproduct string for your adapter .. 0bda:b812)
With an active internet connection, open a terminal and run these commands in sequence:-
sudo apt-get install git dkmsthen
mkdir ~/rtl8822then
cd ~/rtl8822then
git clone https://github.com/jeremyb31/rtl8822bu.gitthen
sudo dkms add ./rtl8822buthen
sudo dkms install 8822bu/1.1then
sudo modprobe 8822budid wireless spring to life ?
If so, does it survive a reboot ?
« Reply #7 on: April 12, 2018, 11:34:29 am »
HI ggsinclair, how’s it going :)?  For future reference, could you please remember to encapsulate all terminal outputs with the Insert, Code # function.  For extra long outputs, please use the Spoiler, Sp function.  If you’re a Chromium Browser and/or a Google Chrome user, please don't combine these functions.  For some reason they don’t work well together with these browsers.  Only use one or the other  ;).  These forum functions preserve the original format of the output.  This makes it easier for future visitors to relate to their own issues.  These functions are found in the forum editor, above the,  :-[ Embarrassed and  the :'( Cry emoticon respectively.  Use the Preview button to check how it'll look in the forum.  This time, I've done it for you - many thanks  ;).
Offline ggsinclair
« Reply #8 on: April 12, 2018, 01:14:46 pm »
Will do in future.
Fist time I have needed help for 15 years so apologies if I didnt get it right.   ;D
« Reply #9 on: April 12, 2018, 01:15:59 pm »
Have you tried the instructions above ?
If so, did it work ?
Offline ggsinclair
« Reply #10 on: April 12, 2018, 01:21:26 pm »
Hi.
Just tried it.
Working great now thanks.
Have tried so many solutions and this is the only one that worked.
Thank you!
Gordon  :)
« Reply #11 on: April 12, 2018, 01:28:57 pm »
You're most welcome Gordon :)
If/when you're happy with the solution, can you please remember to edit the FIRST posting in this topic and change:-
Thanks in advance :)
« Last Edit: April 12, 2018, 01:31:11 pm by PCNetSpec »
Offline dougmccrary
Re: Subject: Realtek RTL8812BU driver required. (SOLVED)
« Reply #12 on: December 28, 2018, 01:36:55 am »
 :D I've been looking for something that worked with my tp-link Archer t4u(us) v3 for ages (2357:0115).
This is it,  PCNetSpec !
A question: is it expected the activity light on it does not flash (it does on winblows)?
Haven't used it much yet, but otherwise seems OK.
I'm on ubuntu 18.04.1 LTS
Thanks soooo much.
« Last Edit: December 28, 2018, 01:45:23 am by dougmccrary »
« Reply #13 on: December 28, 2018, 05:26:21 am »
Can't answer that off the top of my head dougmccrary, what's the output from:
modinfo 8822bu?
Offline dougmccrary
« Reply #14 on: December 29, 2018, 12:22:55 am »
Longer than I expected, but:
doug@doug-MS-8822:~$ modinfo 8822bu
filename:       /lib/modules/4.15.0-43-generic/updates/dkms/8822bu.ko
version:        v5.1.0-5_17968.20160601_BTCOEX20160411-1400_beta
author:         Brandon Bailey <brandondanielbailey@gmail.com>
description:    Realtek Wireless Lan Driver
license:        GPL
srcversion:     A48BFC555E9A879F646F38E
alias:          usb:v0BDApB82Cd*dc*dsc*dp*icFFiscFFipFFin*
alias:          usb:v2357p0115d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0B05p1841d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0B05p184Cd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v7392pB822d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0B05p1812d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0BDApB812d*dc*dsc*dp*ic*isc*ip*in*
depends:        cfg80211
retpoline:      Y
vermagic:       4.15.0-43-generic SMP mod_unload
signat:         PKCS#7
signer:
sig_key:
sig_hashalgo:   md4
parm:           rtw_ips_mode:The default IPS mode (int)
parm:           rtw_usb_rxagg_mode:int
parm:           rtw_drv_log_level:set log level when insert driver module, default log level is _DRV_INFO_ = 4 (uint)
parm:           rtw_country_code:The default country code (in alpha2) (charp)
parm:           rtw_channel_plan:The default chplan ID when rtw_alpha2 is not specified or valid (int)
parm:           rtw_excl_chs:exclusive channel array (array of uint)
parm:           rtw_btcoex_enable:BT co-existence on/off, 0:off, 1:on, 2:by efuse (int)
parm:           rtw_ant_num:Antenna number setting, 0:by efuse (int)
parm:           rtw_force_igi_lb:force IGI low-bound, 0:no specified (int)
parm:           rtw_qos_opt_enable:int
parm:           ifname:The default name to allocate for first interface (charp)
parm:           if2name:The default name to allocate for second interface (charp)
parm:           rtw_pwrtrim_enable:int
parm:           rtw_initmac:charp
parm:           rtw_special_rf_path:int
parm:           rtw_chip_version:int
parm:           rtw_rfintfs:int
parm:           rtw_lbkmode:int
parm:           rtw_network_mode:int
parm:           rtw_channel:int
parm:           rtw_mp_mode:int
parm:           rtw_wmm_enable:int
parm:           rtw_vrtl_carrier_sense:int
parm:           rtw_vcs_type:int
parm:           rtw_busy_thresh:int
parm:           rtw_ht_enable:int
parm:           rtw_bw_mode:int
parm:           rtw_ampdu_enable:int
parm:           rtw_rx_stbc:int
parm:           rtw_ampdu_amsdu:int
parm:           rtw_vht_enable:int
parm:           rtw_lowrate_two_xmit:int
parm:           rtw_rf_config:int
parm:           rtw_power_mgnt:int
parm:           rtw_smart_ps:int
parm:           rtw_low_power:int
parm:           rtw_wifi_spec:int
parm:           rtw_full_ch_in_p2p_handshake:int
parm:           rtw_antdiv_cfg:int
parm:           rtw_antdiv_type:int
parm:           rtw_drv_ant_band_switch:int
parm:           rtw_switch_usb_mode:int
parm:           rtw_enusbss:int
parm:           rtw_hwpdn_mode:int
parm:           rtw_hwpwrp_detect:int
parm:           rtw_hw_wps_pbc:int
parm:           rtw_max_roaming_times:The max roaming times to try (uint)
parm:           rtw_mc2u_disable:int
parm:           rtw_80211d:Enable 802.11d mechanism (int)
parm:           rtw_notch_filter:0:Disable, 1:Enable, 2:Enable only for P2P (uint)
parm:           rtw_hiq_filter:0:allow all, 1:allow special, 2:deny all (uint)
parm:           rtw_adaptivity_en:0:disable, 1:enable (uint)
parm:           rtw_adaptivity_mode:0:normal, 1:carrier sense (uint)
parm:           rtw_adaptivity_dml:0:disable, 1:enable (uint)
parm:           rtw_adaptivity_dc_backoff:DC backoff for Adaptivity (uint)
parm:           rtw_adaptivity_th_l2h_ini:TH_L2H_ini for Adaptivity (int)
parm:           rtw_adaptivity_th_edcca_hl_diff:TH_EDCCA_HL_diff for Adaptivity (int)
parm:           rtw_amplifier_type_2g:BIT3:2G ext-PA, BIT4:2G ext-LNA (uint)
parm:           rtw_amplifier_type_5g:BIT6:5G ext-PA, BIT7:5G ext-LNA (uint)
parm:           rtw_RFE_type:default init value:64 (uint)
parm:           rtw_powertracking_type:default init value:64 (uint)
parm:           rtw_GLNA_type:default init value:0 (uint)
parm:           rtw_TxBBSwing_2G:default init value:0xFF (uint)
parm:           rtw_TxBBSwing_5G:default init value:0xFF (uint)
parm:           rtw_OffEfuseMask:default open Efuse Mask value:0 (uint)
parm:           rtw_FileMaskEfuse:default drv Mask Efuse value:0 (uint)
parm:           rtw_rxgain_offset_2g:default RF Gain 2G Offset value:0 (uint)
parm:           rtw_rxgain_offset_5gl:default RF Gain 5GL Offset value:0 (uint)
parm:           rtw_rxgain_offset_5gh:uint
parm:           rtw_rxgain_offset_5gm:default RF Gain 5GM Offset value:0 (uint)
parm:           rtw_pll_ref_clk_sel:force pll_ref_clk_sel, 0xF:use autoload value (uint)
parm:           rtw_tx_pwr_lmt_enable:0:Disable, 1:Enable, 2: Depend on efuse (int)
parm:           rtw_tx_pwr_by_rate:0:Disable, 1:Enable, 2: Depend on efuse (int)
parm:           rtw_target_tx_pwr_2g_a:2.4G target tx power (unit:dBm) of RF path A for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_2g_b:2.4G target tx power (unit:dBm) of RF path B for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_2g_c:2.4G target tx power (unit:dBm) of RF path C for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_2g_d:2.4G target tx power (unit:dBm) of RF path D for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_5g_a:5G target tx power (unit:dBm) of RF path A for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_5g_b:5G target tx power (unit:dBm) of RF path B for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_5g_c:5G target tx power (unit:dBm) of RF path C for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_target_tx_pwr_5g_d:5G target tx power (unit:dBm) of RF path D for each rate section, should match the real calibrate power, -1: undefined (array of int)
parm:           rtw_phy_file_path:The path of phy parameter (charp)
parm:           rtw_load_phy_file:PHY File Bit Map (int)
parm:           rtw_decrypt_phy_file:Enable Decrypt PHY File (int)
