Author Topic: (solved) scroll bar size  (Read 2689 times)
Online PCNetSpec
Re: scroll bar size
« Reply #30 on: April 25, 2018, 01:06:40 pm »
I know, just couldn't resist :)
EDIT: Hmm! Your horizontal scrollbar is missing the logo
That would be because there's nothing to scroll, the horizontal scroll handle only appears on pages wider than screen.
besides which, it was a joke .. it looks horrible.
(and I don't use Chrome/Chromium either)
« Last Edit: April 25, 2018, 01:12:03 pm by PCNetSpec »
Re: scroll bar size
« Reply #31 on: April 25, 2018, 01:13:13 pm »
Great!
Usually, if you spend time configuring the "eye candy", you want to show it right?
...and I got a bit curious about the OP's "final" result. "final", because it's never final ... once you start messing with the looks you get addicted
Re: scroll bar size
« Reply #32 on: April 25, 2018, 01:38:45 pm »
I've always been happy with my Peppermint "eye candy", the only thing I do is to move the panel to the top, make it transparent and add plank at the bottom.
That said, my Void system has been my "training ground"
Here is my "final" theme for that set-up...
Equilux-theme, Matcha-icons and the rest is hand-made, including the desktop-analogue-clock... https://forum.voidlinux.eu/t/offical-desktop-screenshot-thread/30/418?u=pin
You see, showing eye-candy
Offline s2
Re: scroll bar size
« Reply #33 on: April 27, 2018, 11:47:21 am »
Care to share a screenshot after all the changes?
how to attach a screenshot or file?
can't find it in reply.
Re: scroll bar size
« Reply #34 on: April 27, 2018, 11:53:12 am »
Hi, see here
https://forum.peppermintos.com/index.php?topic=4036.0
Offline s2
Re: scroll bar size
« Reply #35 on: April 28, 2018, 11:06:24 am »
thanks for the help.
« Last Edit: April 29, 2018, 10:39:28 am by s2 »
Re: scroll bar size
« Reply #36 on: April 28, 2018, 12:04:08 pm »
Nice !
Hope you're happy!
Glad we could help and thx for sharing.
Offline s2
Re: scroll bar size
« Reply #37 on: April 30, 2018, 12:38:05 am »
Nice !
Hope you're happy!
learning a little each day.
appreciate the help.
Offline s2
Re: scroll bar size
« Reply #38 on: April 30, 2018, 12:48:01 am »
close
