Author Topic: (solved) scroll bar size  (Read 2681 times)
Offline s2
Re: scroll bar size
« Reply #15 on: April 17, 2018, 11:45:02 am »
i appreciate the help and taking the time to work with me on this scroll bar issue.
all the tweaks do not have any effect whatsoever.
i have not tried to change any colour.
so, could we try to change the colour?
something simple to see if i am able to manipulate the file.
« Last Edit: April 17, 2018, 11:58:09 am by s2 »
Re: scroll bar size
« Reply #16 on: April 17, 2018, 11:52:19 am »
Have you rebooted the system?
Offline s2
Re: scroll bar size
« Reply #17 on: April 17, 2018, 11:59:14 am »
yes.
no change.
Online PCNetSpec
Re: scroll bar size
« Reply #18 on: April 17, 2018, 12:03:39 pm »
I take it you're making the changes to the Greybird theme ?
Are you actually using the Greybird theme ?
If not, which theme are you using, and where did you get it ?
Re: scroll bar size
« Reply #19 on: April 17, 2018, 12:08:25 pm »
As for the colors it's very simple. You find the hex-code for the color you want to use and change the defaults in a similar way...
Offline s2
Re: scroll bar size
« Reply #20 on: April 19, 2018, 12:19:47 pm »
yes. using Greybird.
Offline s2
Re: scroll bar size
« Reply #21 on: April 19, 2018, 12:21:35 pm »
have not changed the colors yet.
thanks...
Offline s2
Re: scroll bar size
« Reply #22 on: April 23, 2018, 04:05:35 am »
ok.
i have been able to make some changes to both the color background and the slider width.
but the slider-width has not changed in the Chromium window.
any suggestions?
Re: scroll bar size
« Reply #23 on: April 23, 2018, 04:10:24 am »
Hi again,
Is it only chromium? Chromium should be using gtk-3. Do other gtk-3 apps behave like you want them to?
I use firefox and don't have chromium installed.
Online PCNetSpec
Re: scroll bar size
« Reply #24 on: April 23, 2018, 07:18:35 am »
I'm pretty sure Chromium draws its own window decorations (hence why there's no window titlebar in Chrome/Chromium) unless you specifically toggle its "Use system titlebar and borders" setting, but even then I think it still draws its own scrollbars (but I could be wrong).
In Chromium/Chrome, go to
chrome://settings/
and try toggling the "Use system titlebar and borders" setting.
But there is a chrome/chromium extension called "Rescroller" that allows you to change it's scrollbar size/colour
https://chrome.google.com/webstore/detail/rescroller/ddehdnnhjimbggeeenghijehnpakijod?hl=en
You used to be able to easily create/edit a Custom.css for Chrome/Chromium (kinda the equivalent of Firefox's userChrome.css) to apply user customisations .. but it's now just another thing Google decided you shouldn't be allowed to do ::)
« Last Edit: April 23, 2018, 08:02:27 am by PCNetSpec »
Offline s2
Re: scroll bar size
« Reply #25 on: April 25, 2018, 12:05:28 pm »
Hi again,
as of now just Chromium.
i have not noticed any other apps so far.
Offline s2
Re: scroll bar size
« Reply #26 on: April 25, 2018, 12:29:18 pm »
this Rescroller may do the trick.
i am currently experimenting with it.
thanks to all.
Re: scroll bar size
« Reply #27 on: April 25, 2018, 12:40:27 pm »
Care to share a screenshot after all the changes?
Online PCNetSpec
Re: scroll bar size
« Reply #28 on: April 25, 2018, 12:57:26 pm »
(click image to enlarge)
« Last Edit: April 25, 2018, 01:01:22 pm by PCNetSpec »
Re: scroll bar size
« Reply #29 on: April 25, 2018, 01:04:06 pm »
not you... and not of "how to..." in chromium!! Chromium/chrome will never be installed on my systems.
EDIT: Hmm! Your horizontal scrollbar is missing the logo
« Last Edit: April 25, 2018, 01:06:03 pm by pin »
