Author Topic: (SOLVED) How to save the File Manager settings  (Read 3219 times)
Offline jozefmw
« on: July 19, 2014, 01:48:14 am »
I am looking for a way to save the the File Manger settings form 'Icon View' to 'Detailed List View'
Thank you for your solution !
Jozef
« Last Edit: July 19, 2014, 07:57:00 am by jozefmw »
Offline Scott
Hi Jozefmw,
To save the file manager settings open the file manager and click View > Preserve this folder's Settings.
~Scott
Offline jozefmw
Thank you very much. Scott. Problem solved ! ;D
Offline Scott
Re: (SOLVED) How to save the File Manager settings
« Reply #3 on: July 19, 2014, 10:07:11 am »
You're welcome, Jozefmw. Happy to know the problem is fixed.  :)
« Reply #4 on: July 19, 2014, 10:27:45 am »
That will only save the setting for a single folder .. you'll have to repeat that for EVERY folder.
There *is* a way to make it the *default* view mode if you'd prefer.....
Make sure ALL File manager windows are closed and leave them closed.  <-- this is important because if you open a fie manager window and close it again before you log off/on it will overwrite the pcmanfm.conf file with the current settings again
Open a terminal with Ctrl+Alt+T
Run:
gedit ~/.config/pcmanfm/peppermint/pcmanfm.conf
find the line that reads:-
view_mode=icon
and change it to
view_mode=list
SAVE the file and exit gedit.
Now log off/on  (DO NOT open a file manager window before logging off/on).
After logging back on the pcmanfm file manager will open ALL folders in "Detailed List" view by default.
Options appear to be:-
view_mode=icon
view_mode=compact
view_mode=thumbnail
view_mode=list
« Last Edit: July 19, 2014, 10:44:17 am by PCNetSpec »
