Author Topic: PIV OR CAC card reader  (Read 2143 times)
Offline ScubaSteve
  • Peppermint version(s): PeppermintOS 8 64 bit
« on: April 04, 2018, 07:50:21 pm »
Trying to use the Citrix App in Chromium for remote access at work, but need a PIV or CAC card reader installed first. Anyone been success with this? Plugging to the USB does nothing right now.
Offline ScubaSteve
Re: PIV OR CAC card reader
« Reply #1 on: April 04, 2018, 07:54:04 pm »
steve@steve-ThinkPad-T430 ~ $ inxi -Fz
System:    Host: steve-ThinkPad-T430 Kernel: 4.13.0-32-generic x86_64 (64 bit)
Machine:   System: LENOVO (portable) product: 2344BPU v: ThinkPad T430
           Mobo: LENOVO model: 2344BPU v: Win8 Pro DPK TPG
           Bios: LENOVO v: G1ETA7WW (2.67 ) date: 12/08/2014
CPU:       Dual core Intel Core i7-3520M (-HT-MCP-) cache: 4096 KB
           clock speeds: max: 3600 MHz 1: 2893 MHz 2: 2893 MHz 3: 2893 MHz
           4: 2893 MHz
Graphics:  Card-1: Intel 3rd Gen Core processor Graphics Controller
           Card-2: NVIDIA GF108M [NVS 5400M]
           Display Server: X.Org 1.19.5 driver: nvidia
           Resolution: 1600x900@60.00hz
           GLX Renderer: NVS 5400M/PCIe/SSE2 GLX Version: 4.5.0 NVIDIA 384.111
Audio:     Card Intel 7 Series/C210 Series Family High Definition Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.13.0-32-generic
Network:   Card-1: Intel 82579LM Gigabit Network Connection driver: e1000e
           IF: enp0s25 state: down mac: <filter>
           Card-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
Drives:    HDD Total Size: 500.1GB (4.3% used)
           ID-1: /dev/sda model: HGST_HTS725050A7 size: 500.1GB
Partition: ID-1: / size: 451G used: 13G (3%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 8.27GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 63.0C mobo: N/A gpu: 59C
           Fan Speeds (in rpm): cpu: 3994
Info:      Processes: 197 Uptime: 1:07 Memory: 1386.6/7678.5MB
« Reply #2 on: April 04, 2018, 09:59:06 pm »
Hi Steve
I know nothing about these card readers but you may need to install coolkey and pcsc-tool both are in the repos
the first thing would be to find out if the system is seeing it, could you post the output of the following
lsusb
Here's some info that might help setting it up in Firefox (I know you're using Chromium but it might help)
https://militarycac.com/PDFs/Mint15_CAC_CARD_Instructions.pdf
Good luck
« Last Edit: April 05, 2018, 10:05:44 pm by emegra »
Offline ScubaSteve
« Reply #3 on: April 05, 2018, 08:46:22 pm »
So it looks like it will read the SCR (smart card reader), but nothing when I put the CAC/PIV card in. I would imagine this means I need the coolkeys and PCSC stuff. I will install tomorrow.
I have read that CAC guide, but will definitely need some help deciphering. The first hurdle crossed though. I appreciate the help.
steve@steve-ThinkPad-T430 ~ $ lsusb
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 005: ID 04f2:b2db Chicony Electronics Co., Ltd
Bus 001 Device 004: ID 0a5c:21e6 Broadcom Corp. BCM20702 Bluetooth 4.0 [ThinkPad]
Bus 001 Device 003: ID 147e:2020 Upek TouchChip Fingerprint Coprocessor (WBF advanced mode)
Bus 001 Device 007: ID 04e6:5116 SCM Microsystems, Inc. SCR331-LC1 / SCR3310 SmartCard Reader
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
« Reply #4 on: April 06, 2018, 07:54:19 am »
Yep, looks like you need to install
sudo apt-get install libpcsclite1 pcscd pcsc-toolsthen import your CA certificate.
Offline christianvl
« Reply #5 on: April 06, 2018, 09:30:11 am »
Here is what I do here in Brazil
sudo apt install libengine-pkcs11-openssl libp11-2 libpcsc-perl libccid libpcsclite1 pcscd pcsc-tools libasedrive-usb opensc libssl1.0.0 openssl libopensc-openssl
Then
sudo addgroup scard
sudo adduser “YOUR-USERNAME” scard
then you'll need to install the driver for the card reader. This will depend on the model you're using.
I usually use this one http://www.validcertificadora.com.br/upload/downloads/linux64bits/safesignidentityclient_3.0.77-Ubuntu_amd64.deb
But you'll have to force install it, because it depends on some packages that are no longer available in Ubuntu.
sudo dpkg --force-all -i safesignidentityclient_3.0.77-Ubuntu_amd64.deb
And then
sudo pluma /var/lib/dpkg/status
Do a "ctrl+f" find for “safesign”, look for the field "depends" and delete libwxbase2.8-0 (>= 2.8.12.1) and libwxgtk2.8-0 (>= 2.8.12.1)
Mind that you still have to install your certificates.
EDIT
Corrected a typo
Thank you PCNetSpec!
EDIT 2
Corrected other typo in the commands
« Last Edit: April 08, 2018, 04:33:49 am by christianvl »
Offline ScubaSteve
« Reply #6 on: April 07, 2018, 12:55:42 pm »
So I have completed this.
steve@steve-ThinkPad-T430 ~ $ sudo apt-get install libpcsclite1 pcscd pcsc-tools
[sudo] password for steve:
Reading package lists... Done
Building dependency tree
libpcsclite1 is already the newest version (1.8.14-1ubuntu1.16.04.1).
libpcsclite1 set to manually installed.
The following packages were automatically installed and are no longer required:
  fonts-linuxlibertine linux-headers-4.4.0-101 linux-headers-4.4.0-101-generic
  linux-image-4.4.0-101-generic linux-image-extra-4.4.0-101-generic
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  libccid libpcsc-perl
Suggested packages:
  pcmciautils
  libccid libpcsc-perl pcsc-tools pcscd
0 upgraded, 4 newly installed, 0 to remove and 209 not upgraded.
Need to get 273 kB of archives.
After this operation, 928 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
Get:1 http://us.archive.ubuntu.com/ubuntu xenial/universe amd64 libpcsc-perl amd64 1.4.14-1build1 [43.8 kB]
Get:2 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 libccid amd64 1.4.22-1ubuntu0.1 [85.8 kB]
Get:3 http://us.archive.ubuntu.com/ubuntu xenial/universe amd64 pcsc-tools amd64 1.4.25-1 [87.7 kB]
Get:4 http://us.archive.ubuntu.com/ubuntu xenial-updates/universe amd64 pcscd amd64 1.8.14-1ubuntu1.16.04.1 [55.7 kB]
Fetched 273 kB in 0s (892 kB/s)
Selecting previously unselected package libpcsc-perl.
(Reading database ... 351252 files and directories currently installed.)
Preparing to unpack .../libpcsc-perl_1.4.14-1build1_amd64.deb ...
Unpacking libpcsc-perl (1.4.14-1build1) ...
Selecting previously unselected package libccid.
Preparing to unpack .../libccid_1.4.22-1ubuntu0.1_amd64.deb ...
Unpacking libccid (1.4.22-1ubuntu0.1) ...
Selecting previously unselected package pcsc-tools.
Preparing to unpack .../pcsc-tools_1.4.25-1_amd64.deb ...
Unpacking pcsc-tools (1.4.25-1) ...
Selecting previously unselected package pcscd.
Preparing to unpack .../pcscd_1.8.14-1ubuntu1.16.04.1_amd64.deb ...
Unpacking pcscd (1.8.14-1ubuntu1.16.04.1) ...
Processing triggers for man-db (2.7.5-1) ...
Processing triggers for bamfdaemon (0.5.3~bzr0+16.04.20160824-0ubuntu1) ...
Rebuilding /usr/share/applications/bamf-2.index...
Processing triggers for desktop-file-utils (0.22-1ubuntu5.1) ...
Processing triggers for mime-support (3.59ubuntu1) ...
Processing triggers for systemd (229-4ubuntu21.1) ...
Processing triggers for ureadahead (0.100.0-19) ...
ureadahead will be reprofiled on next reboot
Setting up libpcsc-perl (1.4.14-1build1) ...
Setting up libccid (1.4.22-1ubuntu0.1) ...
Setting up pcsc-tools (1.4.25-1) ...
Setting up pcscd (1.8.14-1ubuntu1.16.04.1) ...
But than hit a snag. Terminal says only root can add group, and I have no clue what that means. Moreover I got an error when trying to install the driver. Please see below, and thanks for all the help with this guys.
steve@steve-ThinkPad-T430 ~ $ addgroup scard
addgroup: Only root may add a user or group to the system.
steve@steve-ThinkPad-T430 ~ $ sudo dpkg –force-all -i safesignidentityclient_3.0.77-Ubuntu_amd64.deb
dpkg: error: need an action option
Type dpkg --help for help about installing and deinstalling packages [*];
Use 'apt' or 'aptitude' for user-friendly package management;
Type dpkg -Dhelp for a list of dpkg debug flag values;
Type dpkg --force-help for a list of forcing options;
Type dpkg-deb --help for help about manipulating *.deb files;
Options marked [*] produce a lot of output - pipe it through 'less' or 'more' !
« Reply #7 on: April 07, 2018, 07:43:23 pm »
When you see that message, it's telling you only the root user can execute that command.  Root in Linux has administration rights for everything.  This is very powerful; unfortunately it's also leaves your computer very vulnerable to mistakes and wandering hands  :(.   Basically, you don't want to run your computer as root.  Working from your regular user account, you only have admin rights for things in your user account and things you've granted permission to do.  This regular user account, is the one you sign into when you start your computer.  To safely get around this root user issue, we preface the command with sudo.  This temporarily gives you root user privileges.  I think by default, you have to re-enter your password/passphrase after 15 mins  :-\.  Anyway, it's only temporary access  ;).
This permissions based structure, is inherited from UNIX.  It's brilliantly simple and elegant.  It's what makes Linux so secure.  Don't worry you'll get the hang of it.  It's just a little alien to you at the moment  ;).
« Last Edit: April 08, 2018, 05:24:03 am by AndyInMokum »
Offline christianvl
« Reply #8 on: April 08, 2018, 04:32:14 am »
I'm the one to blame here. I'm sorry, there's a typo (another one) on my post, I'll edit again.
You're supposed to be the sys admin (root) to make the changes. Just add the word sudo befor the commands:
sudo addgroup scard
Replace the word "your-username" with your actual username (I believe it's steve).
For running the dpkg command, it should have been a "--" instead of a "–" (thank you autocorrect). See it again:
Offline ScubaSteve
« Reply #9 on: April 08, 2018, 12:39:13 pm »
No blame Christianvl, I obviously need a lot of hand-holding on this. So the good news is the output for the PIV card reader appears to be working. Please see below. I have taken out some of the info but it does seem to be reading. Still don't think I have successfully installed the drivers though. When I try to access Citrix it instantly says no.
steve@steve-ThinkPad-T430 ~ $ pcsc_scan
PC/SC device scanner
V 1.4.25 (c) 2001-2011, Ludovic Rousseau <ludovic.rousseau@free.fr>
Compiled with PC/SC lite version: 1.8.14
Using reader plug'n play mechanism
Scanning present readers...
0: SCM Microsystems Inc. SCR 3310 [CCID Interface] (53311724217924) 00 00
Sun Apr  8 15:37:48 2018
Reader 0: SCM Microsystems Inc. SCR 3310 [CCID Interface] (53311724217924) 00 00
  Card state: Card inserted,
  ATR: 3B DB 96 00 80 1F 03 00 31 C0 64 B0 F3 10 00 0F 90 00 88
+ TS = 3B --> Direct Convention
+ T0 = DB, Y(1): 1101, K: 11 (historical bytes)
  TA(1) = 96 --> Fi=512, Di=32, 16 cycles/ETU
    250000 bits/s at 4 MHz, fMax for Fi = 5 MHz => 312500 bits/s
  TC(1) = 00 --> Extra guard time: 0
  TD(1) = 80 --> Y(i+1) = 1000, Protocol T = 0
  TD(2) = 1F --> Y(i+1) = 0001, Protocol T = 15 - Global interface bytes following
  TA(3) = 03 --> Clock stop: not supported - Class accepted by the card: (3G) A 5V B 3V
+ Historical bytes: 00 31 C0 64 B0 F3 10 00 0F 90 00
  Category indicator byte: 00 (compact TLV data object)
    Tag: 3, len: 1 (card service data byte)
      Card service data byte: C0
        - Application selection: by full DF name
        - Application selection: by partial DF name
        - EF.DIR and EF.ATR access services: by GET RECORD(s) command
        - Card with MF
    Tag: 6, len: 4 (pre-issuing data)
      Data: B0 F3 10 00
    Mandatory status indicator (3 last bytes)
      LCS (life card cycle): 0F (unknown)
      SW: 9000 (Normal processing.)
+ TCK = 88 (correct checksum)
Possibly identified card (using /usr/share/pcsc/smartcard_list.txt):
  ** here it lists the agency I work for and a number of codes**
But than...
steve@steve-ThinkPad-T430 ~ $ sudo dpkg --force-all -i safesignidentityclient_3.0.77-Ubuntu_amd64.deb
dpkg: error processing archive safesignidentityclient_3.0.77-Ubuntu_amd64.deb (--install):
 cannot access archive: No such file or directory
That is why I am assuming I have not downloaded the driver correctly. Does that sound right. Again thanks for all the help guys.
« Reply #10 on: April 08, 2018, 01:19:20 pm »
If you've got the file in your Downloads directory, first you need to
cd Downloads
Offline christianvl
« Reply #11 on: April 10, 2018, 07:07:40 pm »
Don't give up!
As murraymint pointed, you have to run the dpkg command on the same directory you've downloaded the file.
cd Downloads
« Reply #12 on: April 11, 2018, 07:34:29 am »
I've fixed the dependency issues in safesignidentityclient_3.0.77-Ubuntu_amd64.deb so it now depends on:-
libwxgtk3.0-0v5 instead of libwxgtk2.8-0
libwxbase3.0-0v5 instead of libwxbase2.8-0
You can find the fixed safesignidentityclient_3.0.77-Ubuntu_edited-for-xenial-to-bionic_amd64.deb attached below .. just download it, and double-click it to install.
Also attached a fixed 32bit version safesignidentityclient_3.0.77-Ubuntu_edited-for-xenial-to-bionic_i386.deb
[EDIT2]
If for some reason you ever want to uninstall:-
sudo apt-get remove --purge safesignidentityclient
« Last Edit: April 11, 2018, 08:03:09 am by PCNetSpec »
Offline christianvl
« Reply #13 on: April 11, 2018, 07:49:29 am »
 :o
Thank you very much!
I'll test it ASAP!
« Reply #14 on: April 11, 2018, 08:08:53 am »
Make sure you get the 64bit version (amd64) if you're running Peppermint 7/8 64bit.
or the 32bit version (i386) if you're running Peppermint 7/8 32bit. ;)
NOTE
If for some reason you accidentally installed the 32bit version in 64bit Peppermint 7/8 .. running these commands in sequence should fix things:
sudo apt-get remove --purge safesignidentityclient:i386 libccid:i386 pcscd:i386then:
sudo apt-get autoremovethen:
sudo apt-get install --reinstall libccid pcscdthen go ahead and download and install the 64bit version :)
I only mentioned this because I notice someone has downloaded the 32bit version.
« Last Edit: April 11, 2018, 08:24:48 am by PCNetSpec »
