Author Topic: Desktop icons want to move to the trash  (Read 3538 times)
Re: Desktop icons want to move to the trash
« Reply #15 on: July 22, 2014, 05:27:01 pm »
OK, it's unlikely to be the theme then.
Does it do this with a different mouse ? .. or the touchpad ?
Offline jozefmw
« Reply #16 on: July 23, 2014, 03:42:39 am »
Wht I did not understand is whether I should try all the numbers between 0 and 9 ???   :-\
Jozef
« Reply #17 on: July 23, 2014, 10:35:05 am »
Can't hurt .. you can always set it back to 3 afterwards if necessary.
All that's supposed to do is say how many pixels into the menu are to be ignored if clicked on .. if you get my meaning.
(so if you're on some ind of super high resolution you may even want to try above 9)
Offline jozefmw
« Reply #18 on: July 23, 2014, 05:00:41 pm »
I changed the mouse for another brand.
The problem remains.
To-morrow I will try different numbers.
Thanks for participating in finding a solution.
Jozef
Offline jozefmw
« Reply #19 on: July 24, 2014, 08:53:15 am »
I tried all the numbers between 0 and 11.
Not one was able to solve the problem.
So I put and left it on the number 3
Thank's again for all help.
Jozef
