Author Topic: ALT key conflict  (Read 1311 times)
Offline Teage
ALT key conflict
« on: March 15, 2018, 04:14:31 am »
Hi guys/gals, I'm trying to disable my ALT key and use the SUPER key instead. I need ALT for Blender and Synfig. I used to do this by editing rc.xml on crunchbang. Is there a similar file on Peppermint? I tried the control center but all I have found are keyboard shortcuts and such but not actual key bindings. I have found an xfwm4.xml but does not seem to be what I need. Any help would be greatly appreciated. Thank you..
Re: ALT key conflict
« Reply #1 on: March 15, 2018, 07:41:22 am »
Do you mean you're trying to remove ALT from any keybindings ?
~/.config/peppermint-control-center/xbindkeys.confis where keybindings are stored
This may be of interest
https://forum.peppermintos.com/index.php/topic,6699.msg67996.html#msg67996
[EDIT2]
Or am I completely misunderstanding what you're trying to do ?
« Last Edit: March 15, 2018, 07:44:51 am by PCNetSpec »
« Reply #2 on: March 15, 2018, 07:49:49 am »
Do you just want to remap Super to function as Alt?
Offline Teage
« Reply #3 on: March 15, 2018, 07:57:02 am »
Alt + left click moves the window by default but that is no good when using certain programs that use the alt key for various tasks. I want to remove alt and if possible replace with the super key instead. . I just do not see the binding for ALT+L in keyboard shortcuts from the control center. I do however see another binding for move window ALT+F8 but that is not the right one. I need to disable ALT+L mouse click. Thanks.
Offline Teage
« Reply #4 on: March 15, 2018, 07:58:35 am »
............Yes I don't see why that wouldn't work. As long as it frees up the ALT key that would be great.
Offline Teage
« Reply #5 on: March 15, 2018, 08:04:44 am »
[EDIT2]
...I'm going to try your suggestion. I will let you know how goes. thank ya!
« Reply #6 on: March 15, 2018, 08:39:43 am »
Okay you might want to take a look at the system-wide xfce keybindings at:-
xed /etc/xdg/xfce4/xfconf/xfce-perchannel-xml/xfce4-keyboard-shortcuts.xmland if exists the user specific copy at:-
xed ~/.config/xfce4/xfconf/xfce-perchannel-xml/xfce4-keyboard-shortcuts.xmlboth of which contain the custom properties keybindings .. such as:-
<property name="<Alt>F8" type="string" value="resize_window_key"/>which you might want to change to say
<property name="<Super>F8" type="string" value="resize_window_key"/>or just disable it with
<property name="<Alt>F8" type="empty"/>
« Last Edit: March 15, 2018, 08:49:25 am by PCNetSpec »
