Author Topic: Making snap applicattions appear in the menu  (Read 2058 times)
« on: March 15, 2018, 01:14:39 am »
If you've ever noticed, when you install a snap application they do not show up in the Peppermint 7/8 whiskermenu.
Obviously for any of this to work you'll need to have snapd installed first:
sudo apt-get install snapd
Now here's a workaround so installed snap applications show up in the whiskermenu, open a terminal and create a symlink from the directory snaps store their launchers (/var/lib/snapd/desktop/application) to the system applications directory:
sudo ln -s /var/lib/snapd/desktop/applications /usr/share/applications/snapd
now when you install a snap, such as:
snap install minecraft
or
snap install xnviewmp
or
snap install spotify
all you need to do is log off/on again .. or restart the panel with:
xfce4-panel -r
and the installed snap application should now appear in the whiskermenu.
Further info...
Uninstalling snaps is as simple as
snap remove <application name>
and if you want to know which apps are available as snaps, see here:
https://uappexplorer.com/snaps
Note:- Be aware some snaps (such as Spotify) take a short while to start up the first time they're run, but they start much quicker from then on.
« Last Edit: March 15, 2018, 01:25:42 am by PCNetSpec »
Offline mentha_piperita
Re: Making snap applicattions appear in the menu
« Reply #1 on: June 29, 2018, 09:34:06 am »
Hello everyone.
I had the same problem.
Indeed, the apps are now appearing on the whisker menu but...TWICE.  ???
Any workaround to fix this?
« Reply #2 on: June 29, 2018, 09:40:40 am »
[MIME Cache]
application/epub+zip=coolreader3_cr3.desktop;
application/rtf=coolreader3_cr3.desktop;
application/vnd.kde.okular-archive=okular_org.kde.okular.desktop;
application/x-chm=coolreader3_cr3.desktop;
application/x-fictionbook+xml=coolreader3_cr3.desktop;
application/x-psion-compressed-text=coolreader3_cr3.desktop;
application/x-zip-compressed-fb2=coolreader3_cr3.desktop;
application/xhtml+xml=coolreader3_cr3.desktop;
application/zip=coolreader3_cr3.desktop;
text/html=coolreader3_cr3.desktop;
text/plain=coolreader3_cr3.desktop;
« Reply #3 on: June 29, 2018, 09:59:07 am »
Which version of peppermint ?
Peppermint 9 did not need the above fix, it already had a symlink in place .. all you need to do in Peppermint 9 is either restart the panel or log off/on.
What's the output from
ls -al /usr/share/applications | grep "\->"
« Last Edit: June 29, 2018, 10:05:19 am by PCNetSpec »
« Reply #4 on: July 02, 2018, 10:56:51 am »
Thank you for your help.
I am reinstalling peppermint now.  It was a new install anyway.
I 'll post you back :)
« Reply #5 on: July 02, 2018, 11:07:39 am »
There was no need to reinstall, we could easily fix the dual symlinks.
Offline n6rej
  • Bear
  • Peppermint version(s): peppermint 9
« Reply #6 on: September 28, 2018, 03:04:38 pm »
I discovered the same problem whenever I installed something that said it was from flat group, on peppermint 9
Bear
« Reply #7 on: September 28, 2018, 04:06:36 pm »
Any snap or flatpak (that actually contains a menu entry) installed under Peppermint 9 should show up in the menu after logging out/in (or rebooting)
Or you can just restart the panel with
xfce4-panel -r
THERE IS NO NEED TO CREATE THESE SYMLINKS IN PEPEPRMINT 9
