Author Topic: Not able to connect to the internet through Ethernet  (Read 4463 times)
Offline Kavin
  • Peppermint version(s): 7
Re: Not able to connect to the internet through Ethernet
« Reply #30 on: March 11, 2018, 12:33:16 am »
ok here is the command result that you asked for.
peppermint@peppermint ~ $ sudo fdisk -l
Disk /dev/ram0: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram1: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram2: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram3: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram4: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram5: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram6: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram7: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram8: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram9: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram10: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram11: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram12: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram13: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram14: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/ram15: 64 MiB, 67108864 bytes, 131072 sectors
Disk /dev/loop0: 1.1 GiB, 1162067968 bytes, 2269664 sectors
Disk /dev/sdb: 3.8 GiB, 4026531840 bytes, 7864320 sectors
Disklabel type: dos
Disk identifier: 0xbab3827b
Device     Boot   Start     End Sectors  Size Id Type
/dev/sdb1  *       2048 7823654 7821607  3.7G  7 HPFS/NTFS/exFAT
/dev/sdb2       7823655 7823717      63 31.5K 21 unknown
/dev/sdb4       2511360 4884991 2373632  1.1G  0 Empty
Partition table entries are not in disk order.
Disk /dev/zram0: 495.9 MiB, 519983104 bytes, 126949 sectors
Units: sectors of 1 * 4096 = 4096 bytes
Sector size (logical/physical): 4096 bytes / 4096 bytes
peppermint@peppermint ~ $ sudo blkid
/dev/sdb1: LABEL="E2B" UUID="760002310001F93F" TYPE="ntfs" PARTUUID="bab3827b-01"
/dev/sdb4: UUID="2016-12-01-02-32-49-00" LABEL="Peppermint Seven" TYPE="iso9660" PTUUID="3044e50d" PTTYPE="dos" PARTUUID="bab3827b-04"
/dev/loop0: TYPE="squashfs"
/dev/sdb2: SEC_TYPE="msdos" LABEL="PTN2" UUID="A13C-455C" TYPE="vfat" PARTUUID="bab3827b-02"
/dev/zram0: UUID="eaeecf4e-1a03-4516-becd-ea9cc3e0fae3" TYPE="swap"
I did change the settings for boot preference in bios to boot from liveusb
I do not know if peppermint is still installed because the hard disk itself is not getting detected and if i do not boot from the live usb it does not boot into the os.
@anselm Yes i checked the arrows in gparted it does not show anything else except sdb
Offline Kavin
« Reply #31 on: March 11, 2018, 01:06:53 am »
i got the following errors even while booting from the live usb
These errors run for about 5 mins before booting into the live usb os. What are these errors and what does it indicate?  Also this time the network adapter was not detected and i had to connect my phone to get internet working.
Also can you please tell me if the hdd is working and if not then is there any way to recover the contents from it.
Thank you for all the help and my apologies for any mistakes that i might have done while positng to the forum.
Regards
Kavin
« Reply #32 on: March 11, 2018, 05:52:46 am »
You haven't changed the HDD mode from AHCI to IDE in the BIOS have have you ?
Have you tried resetting the BIOS to defaults ?
