Author Topic: Not able to connect to the internet through Ethernet  (Read 3380 times)
Offline Kavin
  • Peppermint version(s): 7
« on: March 06, 2018, 02:43:17 am »
hello,
I am not able to connect my desktop using ethernet cable to my router. When I connect the router with a cable to the lan card on my desktop , the led turns on at the both the end of the lan card in my desktop and the router but the computer does not show any internet connection.
I am using peppermint 7 on the desktop. I could connect with the same ethernet cable to my laptop which runs Iinum Mint.
The lan card is Realtek semiconductor co., Ltd. RTL-8100/8101L/8139 i think so not sure.
natarajan@natarajan-desktop ~ $ ifconfig
enp1s11   Link encap:Ethernet  HWaddr 00:13:d3:99:7f:66
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
          RX packets:8000 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8000 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:659200 (659.2 KB)  TX bytes:659200 (659.2 KB)
natarajan@natarajan-desktop ~ $ nmcli device status
DEVICE   TYPE      STATE        CONNECTION
enp1s11  ethernet  unavailable  --
lo       loopback  unmanaged    --
natarajan@natarajan-desktop ~ $ lspci
00:00.0 Host bridge: Intel Corporation 82915G/P/GV/GL/PL/910GL Memory Controller Hub (rev 0e)
00:02.0 VGA compatible controller: Intel Corporation 82915G/GV/910GL Integrated Graphics Controller (rev 0e)
00:1d.0 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #1 (rev 05)
00:1d.1 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #2 (rev 05)
00:1d.2 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #3 (rev 05)
00:1d.3 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB UHCI #4 (rev 05)
00:1d.7 USB controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) USB2 EHCI Controller (rev 05)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev d5)
00:1e.2 Multimedia audio controller: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC'97 Audio Controller (rev 05)
00:1f.0 ISA bridge: Intel Corporation 82801FB/FR (ICH6/ICH6R) LPC Interface Bridge (rev 05)
00:1f.1 IDE interface: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) IDE Controller (rev 05)
00:1f.2 IDE interface: Intel Corporation 82801FB/FW (ICH6/ICH6W) SATA Controller (rev 05)
00:1f.3 SMBus: Intel Corporation 82801FB/FBM/FR/FW/FRW (ICH6 Family) SMBus Controller (rev 05)
01:0b.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter (rev 10)
sorry since i have not internet connection on the desktop i am using my laptop to post this information and hence the above has been copy pasted from a text file from the desktop after running the commands on the desktop.
Any help would be greatly appreciated.
Thanking in advance
Kavin
« Last Edit: March 08, 2018, 06:12:06 pm by AndyInMokum »
Re: Not able to connect to the internet through Ethernet
« Reply #1 on: March 06, 2018, 07:04:23 am »
Can you post the output from:
lspci -vnn | grep -i net
sudo lshw -c network
lsmod | grep 81
« Last Edit: March 06, 2018, 07:08:10 am by PCNetSpec »
Offline Kavin
« Reply #2 on: March 06, 2018, 08:53:12 am »
Here are the details:
natarajan@natarajan-desktop ~ $ lspci -vnn | grep -i net
01:0b.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL-8100/8101L/8139 PCI Fast Ethernet Adapter [10ec:8139] (rev 10)
Subsystem: Micro-Star International Co., Ltd. [MSI] RTL-8100/8101L/8139 PCI Fast Ethernet Adapter [1462:131c]
natarajan@natarajan-desktop ~ $ sudo lshw -c network
[sudo] password for natarajan:
  *-network
       product: RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
       physical id: b
       bus info: pci@0000:01:0b.0
       logical name: enp1s11
       version: 10
       serial: 00:13:d3:99:7f:66
       capacity: 100Mbit/s
       width: 32 bits
       clock: 33MHz
       capabilities: pm bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=8139too driverversion=0.9.28 duplex=half latency=32 link=no maxlatency=64 mingnt=32 multicast=yes port=MII speed=10Mbit/s
       resources: irq:23 ioport:d100(size=256) memory:d0010000-d00100ff memory:d0000000-d000ffff
natarajan@natarajan-desktop ~ $ lsmod | grep 81
8139too                32768  0
8139cp                 28672  0
mii                    16384  2 8139cp,8139too
Kavin
« Last Edit: March 08, 2018, 06:13:44 pm by AndyInMokum, Reason: Encapsulating output with [code] »
« Reply #3 on: March 06, 2018, 09:15:56 am »
dmesg | grep 8139
Offline Kavin
« Reply #4 on: March 06, 2018, 09:23:47 am »
natarajan@natarajan-desktop ~ $ dmesg | grep 8139
[    0.122238] pci 0000:01:0b.0: [10ec:8139] type 00 class 0x020000
[   62.122242] 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[   62.122254] 8139cp 0000:01:0b.0: This (id 10ec:8139 rev 10) is not an 8139C+ compatible chip, use 8139too
[   62.158900] 8139too: 8139too Fast Ethernet driver 0.9.28
[   62.161139] 8139too 0000:01:0b.0 eth0: RealTek RTL8139 at 0x0001d100, 00:13:d3:99:7f:66, IRQ 23
[   62.298575] 8139too 0000:01:0b.0 enp1s11: renamed from eth0
[  101.636398] 8139too 0000:01:0b.0 enp1s11: link down
« Last Edit: March 08, 2018, 06:10:36 pm by AndyInMokum, Reason: w »
« Reply #5 on: March 06, 2018, 09:29:11 am »
What happens if you run:
sudo rmmod -f 8139cp
sudo mii-tool enp1s11 -F 100baseT-FD
sudo rmmod -f 8139too
sudo modprobe 8139too
does ethernet then start to work ?
Offline Kavin
« Reply #6 on: March 06, 2018, 09:40:33 am »
This is what i get when i type the commands.
natarajan@natarajan-desktop ~ $ sudo rmmod -f 8139cp
natarajan@natarajan-desktop ~ $ sudo mii-tool enpls11 -F 100baseT-FD
Invalid media specification '100baseT-FD'.
natarajan@natarajan-desktop ~ $ sudo rmmod -f 8139too
natarajan@natarajan-desktop ~ $ sudo modprobe 8139too
The ethernet is still not working.
« Reply #7 on: March 06, 2018, 09:50:07 am »
Try this
sudo mii-tool enp1s11 -F 10baseT-FD
Offline Kavin
« Reply #8 on: March 06, 2018, 10:03:11 am »
natarajan@natarajan-desktop ~ $ sudo mii-tool enpls11 -F 100baseT -FD
Invalid media specification '100baseT'.
Invalid media specification 'D'.
natarajan@natarajan-desktop ~ $ ^C
rmmod: ERROR: ../libkmod/libkmod-module.c:793 kmod_module_remove_module() could not remove '8139cp': No such file or directory
rmmod: ERROR: could not remove module 8139cp: No such file or directory
natarajan@natarajan-desktop ~ $ sudo mii-tool enpls11 -F 10baseT-FD
SIOCGMIIPHY on 'enpls11' failed: No such device
The ethernet still is not working
« Last Edit: March 08, 2018, 06:09:51 pm by AndyInMokum »
« Reply #9 on: March 06, 2018, 10:21:12 am »
Okay let's try something...
But copy/paste these commands to a text file because you're entering some commands incorrectly.
Open a terminal and run:
echo "blacklist 8139cp" | sudo tee /etc/modprobe.d/blacklist-8139cp.conf
sudo update-initramfs -u
gksudo pluma /etc/default/grub
find the line that reads
GRUB_CMDLINE_LINUX=""
and change it to
GRUB_CMDLINE_LINUX="net.ifnames=0 biosdevname=0"
Back in the terminal run:
sudo update-grub
Now REBOOT to test.
To Undo
sudo rm -v /etc/modprobe.d/blacklist-8139cp.conf
and change it to
sudo update-grub
Now REBOOT, and you'll be back where you are now.
« Last Edit: March 06, 2018, 10:23:05 am by PCNetSpec »
Offline Kavin
« Reply #10 on: March 06, 2018, 10:57:48 am »
I copy pasted the commands in a text file and ran them as suggested by you but there was no difference in the ethernet connection.
« Reply #11 on: March 06, 2018, 11:43:57 am »
What happens if you now run:
sudo mii-tool eth0 -F 10baseT-FD
I take it you've tried the cable in a different port on the router ?
Offline Kavin
« Reply #12 on: March 07, 2018, 02:15:48 am »
natarajan@natarajan-desktop ~ $ sudo mii-tool eth0 -F 10baseT-FD
SIOCGMIIPHY on 'eth0' failed: No such device
The status remains the same as before no ethernet connection and yes i have tried it in different ports on the router.
« Reply #13 on: March 07, 2018, 08:50:02 am »
Can you run:
dmesg > ~/Desktop/dmesg-output.txt
you should then see a text file on your desktop called "dmesg-output.txt"
Can you host that on a site such as
http://www.tinyupload.com/
and post a link to it here.
Has this hardware ever been tested in another OS ?
« Last Edit: March 07, 2018, 08:52:14 am by PCNetSpec »
Offline anselm
  • Peppermint version(s): 8.5(64 bit)
« Reply #14 on: March 07, 2018, 09:44:51 am »
Have you tried another PCI slot on your motherboard, does your motherboard have its own Ethernet port?
What type of computer.
