Author Topic: Dev/sda1 contains a file system with errors, check forced. Deleted inode 4725293 has zero dtime. FIX  (Read 5495 times)
Offline robertsala
Can you tell us what the actual problem/symptoms is/are, and when it started .. A screenshot on its own with no context isn't all that descriptive ;)
What are you trying to do that isn't happening ?
I mean is Peppermint installed and just started to refuse to boot ?
It's suggesting you run fsck manually .. so boot to a Peppermint LiveCD/LiveUSB then do nothing that might mount sda1 .. just open a terminal (Ctrl+Alt+T) and run:
sudo fsck /dev/sda1
« Last Edit: July 19, 2014, 11:55:41 am by PCNetSpec »
