Author Topic: xfce4-weather-plugin updated.  (Read 3855 times)
« on: February 20, 2018, 06:27:23 pm »
I noticed if you installed the xfce4-weather-plugin (0.8.9) and added it to the panel you were unable to select your location (search didn't work).
So I've backported the 0.8.10 version from 18.04 to Peppermint 8
If you want to install it, run:
sudo apt-get update && sudo apt-get install xfce4-weather-pluginThen right-click on the panel and select:-
Panel > Add New Items
and add the "Weather Update" plugin.
Once on the panel, right-click it and set your "Properties".
Offline tinkereR
  • Consciously Eclectic
  • Peppermint version(s): Peppermint 8 Respin
Re: xfce4-weather-plugin updated.
« Reply #1 on: February 20, 2018, 07:14:16 pm »
Just received the update here. Plugin works well, with one caveat:
There is a font issue with the Peppermix light themes that causes the text to appear too dark. Noticed this in 0.8.9 as well.
i7 4790k @4.4 GHz, MSI Z97 PC Mate, EVGA GTX 950, HyperX  x2 8 GB (16 GB) DDR3, Adata SU650 240 GB, 2 TB WD Green 5400 RPM, 2 TB Seagate Barracuda 7200 RPM
« Reply #2 on: February 20, 2018, 07:24:34 pm »
Can't you just change the font colour .. in the preferences (as in your pic) .. I can.
Just click that Black box to the right of "Select font" .. then choose your colour.
« Last Edit: February 20, 2018, 07:26:34 pm by PCNetSpec »
Offline tinkereR
« Reply #3 on: February 20, 2018, 07:32:21 pm »
Yeah I've figured that much out. I just found it somewhat interesting since other partial-dark gtk themes don't have this issue. (numix as an example)
No biggie either way. :)
« Last Edit: February 20, 2018, 07:35:02 pm by 11ryanc »
« Reply #4 on: February 20, 2018, 07:36:11 pm »
Okay thanks :)
Offline PeppermintFan
  • Peppermint tastes good
  • Peppermint version(s): 7 & 8
« Reply #5 on: April 23, 2018, 07:18:53 pm »
Quick question on the XFCE Weather Plugin.  I have it installed and I'm wondering if there is a way to "auto click" on it for startup.  So the Weather Report window will open automatically on boot.  It is in the tray just fine...but have it actually open.
Thanks for any suggestions.
« Reply #6 on: April 24, 2018, 12:37:49 pm »
I don't think this is possible (some panel plugins have command interfaces, but most don't) .. maybe there is a different desktop weather app someone knows about ?
Offline Dobri
  • Bah
  • Peppermint version(s): TEN (64)
« Reply #7 on: April 26, 2018, 01:05:42 am »
Nice Thanks  :)
WARNING: Military software detected, top secret clearance required
Offline stevesveryown
  • Peppermint Fan
    • stevesveryown
« Reply #8 on: April 29, 2018, 07:22:17 am »
If you're looking for a customizable, nice looking desktop weather widget try this one.
https://sourceforge.net/projects/gis-weather/
« Reply #9 on: April 29, 2018, 06:56:08 pm »
Thanks!  I tried this and I like it!
  • Peppermint Fan
    • stevesveryown
« Reply #10 on: April 29, 2018, 07:20:58 pm »
You are welcome!
« Reply #11 on: July 10, 2018, 07:44:51 am »
I use My -Weather-Indicator easily installed using these commands;
sudo add-apt-repository ppa:atareao/atareao
sudo apt-get update
sudo apt-get install my-weather-indicator
