Author Topic: virtualbox vm installs require you to run ./VBoxLinuxAdditions.run twice  (Read 988 times)
Offline osde8info
virtualbox peppermint vm installs require you to run ./VBoxLinuxAdditions.run twice
run VBoxLinuxAdditions.run
it fails with the error "modprobe vboxsf failed"
reboot
it fails
it works
# ./VBoxLinuxAdditions.run
Verifying archive integrity... All good.
Uncompressing VirtualBox 5.2.6 Guest Additions for Linux........
VirtualBox Guest Additions installer
Copying additional installer modules ...
Installing additional modules ...
VirtualBox Guest Additions: Building the VirtualBox Guest Additions kernel modules.
VirtualBox Guest Additions: Running kernel modules will not be replaced until the system is restarted
VirtualBox Guest Additions: Starting.
VirtualBox Guest Additions: modprobe vboxsf failed
# cat y.y
Removing installed version 5.2.6 of VirtualBox Guest Additions...
Re: virtualbox vm installs require you to run ./VBoxLinuxAdditions.run twice
« Reply #1 on: February 10, 2018, 10:24:56 am »
How did you install Vbox ?
And why are you manually running the guest additions installer from the commandline ? .. in the VM if you navigate into the guest addition CD, there's a button in Nemo labelled "Open Autorun Prompt" .. just click that.
I've never had an issue doing that.
