Author Topic: How do i update flash?  (Read 2654 times)
Re: How do i update flash?
« Reply #15 on: February 06, 2018, 04:07:28 pm »
I'm after the line that starts
Version:
in Firefox
about:plugins
and is there only one listed ?
chadwix
  • Guest
« Reply #16 on: February 06, 2018, 04:40:53 pm »
Version:
in Firefox
about:plugins
That one is also listed, but there are only two in "Add-ons"
OpenH264 Video Codec provided by Cisco
https://s9.postimg.org/6tn7pdp7z/Screenshot_2018-02-06_19_59_21.png
« Last Edit: February 06, 2018, 04:59:48 pm by chadwix »
Offline DAMIEN1307
« Reply #17 on: February 06, 2018, 10:10:56 pm »
OK...i now have a good one for ya...just did 2 new installs of peppermint on previous win 10 systems...(i am now up to at last i can remember 73 installs of peppermint at this time)(all of the linux mint installs i previously did, i re-installed peppermint)...gave them the same 2 browsers i have...slimjet (flash is "161") and chromium (flash is still 137)...as you might know the chromium is my problem on my daily driver of getting "161" adobe flash to work on my chromium browser...on both new installs...it is there (both versions of flash on both new installs show "161' flash installs)...go back to my main everyday driver,...go to my synaptic...make it run identical...will not happen...both new installs shows chromium running "161" flash...on mine?...doesnt matter what i do including reboots etc...stilll stuck at "137"...what am i doing wrong?...if not wrong, re-install only option?...i would rather not re-install but can do...DAMIEN
« Last Edit: February 07, 2018, 01:08:57 am by DAMIEN1307 »
ORDO AB CHAO
Offline DAMIEN1307
« Reply #18 on: February 07, 2018, 01:03:42 am »
i now know I have an answer to this problem of "137" verses "161" flash problem,...you are not going to like it...when i re-post,...it will be under the general category, since i do not think it will be appropriate in this thread...DAMIEN
ORDO AB CHAO
