Author Topic: Desktop Issue After Boot (Solved)  (Read 5800 times)
Re: Desktop Issue After Boot
« Reply #60 on: August 21, 2018, 12:22:21 pm »
Hi Ralph,
And a karma point from me too (same reasons)!
Offline Ralph
  • Peppermint version(s): I've used 4,5,6,7,8,9
« Reply #61 on: March 05, 2019, 08:50:15 am »
Another update and the last. Earlier, I thought Peppermint 9 solved my original post. As it turned out it did not. When 9 started acting like 8r I was beside myself. What the heck is going on. I have figured out over these past months that booting up on this machine with this hardware setup just doesn't like cool ambient temperatures of around 50 degrees F. (10C.)  I noticed that the issue showed up again during the same months as the original post. So,because rebooting would work every time I thought I would try and delay the boot in the bios leaving the POST screen on for 20 seconds or so. It worked. Default on the POST screen was 1 second. No other computer that I store at that temperature acts like this machine. So all this is hardware related and why it's happening I'll never know.
A little knowledge is dangerous, I'm proof of it.
Re: Desktop Issue After Boot (Solved)
« Reply #62 on: March 05, 2019, 01:34:06 pm »
Weird :-\
