Author Topic: Desktop Issue After Boot (Solved)  (Read 6433 times)
Offline Ralph
  • Peppermint version(s): I've used 4,5,6,7,8,9
Re: Desktop Issue After Boot
« Reply #30 on: February 03, 2018, 03:51:28 pm »
I went to install Peppermint 8 respin. When I booted to the usb install media all those errors showed up while loading. I know for a fact I checked the Md5sum to verify the download following the directions from the Peppermint website.
I decided not to install the respin and instead installed P8. No error messages. I did all the usual and customary updates and rebooted. Again no errors. The only errors if they are errors is during the dist-upgrade I saw this:
warning: file-aligned section .text extends beyond end of file
warning: checksum areas are greater than image size. Invalid section table?
I don't know if it means anything or not.
I will test tomorrow to see if all is right. Here's hoping.
A little knowledge is dangerous, I'm proof of it.
Offline Ralph
« Reply #31 on: February 06, 2018, 01:40:04 pm »
Here's an update of this issue which I seem to be the only one having. Peppermint 8 reacts the same as 8 respin but without the errors when I start to boot. Following the suggestion to try other distros in no particular order I tried Ubuntu, Mint, Manjaro, and Netrunner.  All of these had the same issue I have been experiencing and all showed the same error message at boot that I was seeing in P8r.
The last distro I tried and I'm currently trying to iron out on this new Coffee Lake build is Debian 9.3-xface. It seems to work just fine. It throws the errors at startup but boots right to the desktop from a stone cold start. Why it is working I don't have a clue. The only thing I observed is the kernel is 4.09 vs. 4.13 and there is no quiet splash. I think it takes longer to boot. Probably because there is so many crap applications I don't need. I really don't like it as much as Peppermint. I have had to work much harder to get things set up. Like wifi, bluetooth,and the printer just to name a few.
I hope that in time I can switch back to Peppermint on this new build. If anyone could venture to guess why this Debian is working while the others do not I would like to know.  Also, I was just wondering if I switch back to kernel 4.09 with Peppermint if that would have worked. Again Just wondering.
« Reply #32 on: February 06, 2018, 02:55:25 pm »
Can you post the output from:
uname -a
lshw -C display
in Debian
Offline Ralph
« Reply #33 on: February 06, 2018, 03:38:25 pm »
your request
buz@buz:~$ su
Password:
root@buz:/home/buz# uname -a
Linux buz 4.9.0-5-amd64 #1 SMP Debian 4.9.65-3+deb9u2 (2018-01-04) x86_64 GNU/Linux
root@buz:/home/buz# lshw -C display
  *-display UNCLAIMED
       description: VGA compatible controller
       product: Intel Corporation
       vendor: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       version: 00
       width: 64 bits
       clock: 33MHz
       capabilities: pciexpress msi pm vga_controller bus_master cap_list
       configuration: latency=0
       resources: memory:de000000-deffffff memory:c0000000-cfffffff ioport:f000(size=64) memory:c0000-dffff
root@buz:/home/buz#
« Reply #34 on: February 06, 2018, 05:40:53 pm »
Out of interest, have you got a graphics card you can put in that PC just as a test ?
Offline Ralph
« Reply #35 on: February 07, 2018, 07:12:22 am »
I have a Nvidia GTX 750 installed on another machine that I put there for no reason other than I had it. To put it in this SilverStone SUGO Series SG13  on this mitx board may prove to be a task. Things are somewhat cramped in there. I think it would fit but it may not.
If I except this challenge and all goes well, I assume you would want me to try Peppermint 8 respin again. True?
« Reply #36 on: February 07, 2018, 10:12:22 am »
Basically I'm trying to figure out if it **IS** actually a graphics and therefore kernel issue or something else entirely that we're overlooking .. so yes please.
Offline Ralph
« Reply #37 on: February 07, 2018, 10:23:44 am »
I will get back. This will take some time. Thanks for your patience.
Offline Ralph
« Reply #38 on: February 07, 2018, 02:12:07 pm »
I have installed the GTX 750 and reinstalled Peppermint 8 respin.  I have not installed the nvidia drivers as of yet. I wait for what you would like me to try next.
System:    Host: agstone Kernel: 4.13.0-32-generic x86_64 (64 bit) Desktop: N/A
           Distro: Peppermint Eight
Machine:   Mobo: ASRock model: Z370M-ITX/ac
           Bios: American Megatrends v: P1.60 date: 11/30/2017
CPU:       Quad core Intel Core i3-8100 (-MCP-) cache: 6144 KB
           clock speeds: max: 3600 MHz 1: 3600 MHz 2: 3600 MHz 3: 3600 MHz
           4: 3600 MHz
Graphics:  Card: NVIDIA GM107 [GeForce GTX 750]
           Display Server: X.org 1.19.5 drivers: nouveau (unloaded: fbdev,vesa)
           tty size: 86x26 Advanced Data: N/A for root
Audio:     Card-1 NVIDIA Device 0fbc driver: snd_hda_intel
           Card-2 Intel 200 Series PCH HD Audio driver: snd_hda_intel
           Sound: Advanced Linux Sound Architecture v: k4.13.0-32-generic
Network:   Card-1: Intel Ethernet Connection (2) I219-V driver: e1000e
           IF: enp0s31f6 state: down mac: <filter>
           Card-2: Intel I211 Gigabit Network Connection driver: igb
           IF: enp3s0 state: up speed: 100 Mbps duplex: full mac: <filter>
           Card-3: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
           IF: wlp4s0 state: down mac: <filter>
Drives:    HDD Total Size: 525.1GB (3.9% used)
           ID-1: /dev/sda model: Crucial_CT525MX3 size: 525.1GB
Partition: ID-1: / size: 466G used: 4.1G (1%) fs: ext4 dev: /dev/sda2
           ID-2: swap-1 size: 17.11GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Sensors:   System Temperatures: cpu: 23.0C mobo: N/A gpu: 18.0
Info:      Processes: 171 Uptime: 8 min Memory: 532.9/15975.5MB
           Client: Shell (sudo) inxi: 2.2.35
uname-a
uname -a
Linux agstone 4.13.0-32-generic #35~16.04.1-Ubuntu SMP Thu Jan 25 10:13:43 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
lshw
*-display
       product: GM107 [GeForce GTX 750]
       vendor: NVIDIA Corporation
       physical id: 0
       bus info: pci@0000:01:00.0
       version: a2
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress vga_controller bus_master cap_list rom
       configuration: driver=nouveau latency=0
       resources: irq:123 memory:de000000-deffffff memory:c0000000-cfffffff memory:d0000000-d1ffffff ioport:e000(size=128) memory:c0000-dffff
« Reply #39 on: February 07, 2018, 02:14:19 pm »
Are you still getting the issue(s) ?
Offline Ralph
« Reply #40 on: February 07, 2018, 03:17:11 pm »
I had to wait an hour and I just started it up and  :'( :( :-\ YES. Dang
« Reply #41 on: February 07, 2018, 03:25:56 pm »
Okay so it's not graphics .. I'll see what I can find online about problems with coffee lake and/or your motherboard in Ubuntu, but on my travels so far I'd not spotted anything :-\
Did we ever try the 4.4 kernel in Peppermint (or any other *buntu) ?
« Last Edit: February 07, 2018, 03:28:17 pm by PCNetSpec »
Offline Ralph
« Reply #42 on: February 07, 2018, 03:51:57 pm »
No. I didn't know there was such an animal.
« Reply #43 on: February 07, 2018, 05:40:00 pm »
Okay, what's the output from:
dpkg -l | grep 4.13.0
Offline Ralph
« Reply #44 on: February 08, 2018, 06:35:33 am »
grep 4.13.0
ii  linux-generic-hwe-16.04                     4.13.0.32.52                                                amd64        Complete Generic Linux kernel and headers
ii  linux-headers-4.13.0-32                     4.13.0-32.35~16.04.1                                        all          Header files related to Linux kernel version 4.13.0
ii  linux-headers-4.13.0-32-generic             4.13.0-32.35~16.04.1                                        amd64        Linux kernel headers for version 4.13.0 on 64 bit x86 SMP
ii  linux-headers-generic-hwe-16.04             4.13.0.32.52                                                amd64        Generic Linux kernel headers
ii  linux-image-4.13.0-32-generic               4.13.0-32.35~16.04.1                                        amd64        Linux kernel image for version 4.13.0 on 64 bit x86 SMP
ii  linux-image-extra-4.13.0-32-generic         4.13.0-32.35~16.04.1                                        amd64        Linux kernel extra modules for version 4.13.0 on 64 bit x86 SMP
ii  linux-image-generic-hwe-16.04               4.13.0.32.52                                                amd64        Generic Linux kernel image
ii  linux-signed-generic-hwe-16.04              4.13.0.32.52                                                amd64        Complete Signed Generic Linux kernel and headers
ii  linux-signed-image-4.13.0-32-generic        4.13.0-32.35~16.04.1                                        amd64        Signed kernel image generic
ii  linux-signed-image-generic-hwe-16.04        4.13.0.32.52                                                amd64        Signed Generic Linux kernel image
« Last Edit: February 08, 2018, 08:05:42 am by Ralph »
