Author Topic: Peppermint OS 7 to 8??  (Read 1163 times)
Offline theone
  • Loving The peppermint
« on: January 31, 2018, 08:42:14 am »
So is the only way to go fresh install???  Or is there an update I can do that I don't know about?
TIA
Sent from my ONE A2003 using Tapatalk
Re: Peppermint OS 7 to 8??
« Reply #1 on: January 31, 2018, 08:48:05 am »
Hi theone,
A fresh install is the only way...  There are many similar posts on this Forum providing the same answer.
Offline theone
« Reply #2 on: February 02, 2018, 10:35:36 am »
Suspected that, did search but nothing was diffinative. But thanks have started the backup ready, and gives me the excuse to clear some files not needed now [emoji106]
« Reply #3 on: February 02, 2018, 12:35:13 pm »
Only if you really want to do this. The EOL for PM7 and PM8 are the same, i.e 2021 for both.
Regards
