Author Topic: Automount Partitions (Solved)  (Read 1502 times)
Offline Brotherred
  • No0b
  • Peppermint version(s): Pep 8 on 386, Pep 10 on AMD 64
« on: January 28, 2018, 05:53:08 pm »
I have partitions that I can't get to automount even though Disks says that they are set that way.
they are /media/mobileme/Dropbox and /media/mobileme/data
Here is the /etc/fstab contents:
# / was on /dev/sda9 during installation
UUID=0ef0d2d3-4a06-4acc-9103-4742e1983e0f /               ext4    errors=remount-ro 0       1
# swap was on /dev/sda5 during installation
#UUID=94835165-0ec7-4581-96e1-34524911b6e5 none            swap    sw              0       0
/dev/mapper/cryptswap1 none swap sw 0 0
BTW I don't have any problems with cryptswap like I used to on other Peppermint versions.
Regards
« Last Edit: February 09, 2018, 10:55:13 pm by Brotherred »
Re: Automount Partitions
« Reply #1 on: January 29, 2018, 05:10:56 am »
Is this a full disk encryption setup ?
And though you've given the  intended mount points you've not stated the partitions UUID's or device nodes ?
What exactly are these devices .. I can see one is dropbox (which really should be done via the Drpobox client), but I'm not sure what the other is .. is it always attached ?
Offline Brotherred
  • No0b
« Reply #2 on: January 31, 2018, 10:45:14 pm »
Yes these drives are always attached. I typically have Dropbox on it's own partition. I use the Dropbox client to tell drop box to look to that location. So there is no problem there I don't think except that the drive will not mount automatically. I did not have this issue with this drive set up on Peppermint 6. The drive is internal and all of the partitions are on the same drive. There is only one physical drive on the system.
Here is the inxi output that I should have shared.
Drives:    HDD Total Size: 80.0GB (32.7% used) ID-1: /dev/sda model: WDC_WD800BEVE size: 80.0GB
ID-1: / size: 26G used: 11G (45%) fs: ext4 dev: /dev/sda6
           ID-2: /home/mobileme size: 26G used: 11G (45%) fs: ecryptfs dev: N/A
           ID-3: /media/mobileme/data size: 30G used: 259M (1%) fs: ext4 dev: /dev/sda8
           ID-4: /media/mobileme/Dropbox size: 4.4G used: 3.0G (72%) fs: ext4 dev: /dev/sda7
Thank you Regards
« Reply #3 on: February 01, 2018, 06:04:30 am »
Can you manually mount the partitions .. then post the output from:
mountand
sudo fdisk -land
sudo blkid
« Last Edit: February 01, 2018, 06:08:25 am by PCNetSpec »
Offline Brotherred
  • No0b
« Reply #4 on: February 06, 2018, 10:54:35 pm »
By the way since noticing this issue I have also made it so both GMX and Google Drive cloud services can access their own directories on /media/mobileme/Dropbox
This has not changed the configuration at all. I have to manually reinitialize those just like i have had to do with Dropbox after manually mounting the drive. I am sharing it just in case anything not discussed shows up.
$ mount
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
udev on /dev type devtmpfs (rw,nosuid,relatime,size=991916k,nr_inodes=208260,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
tmpfs on /run type tmpfs (rw,nosuid,noexec,relatime,size=202792k,mode=755)
/dev/sda6 on / type ext4 (rw,relatime,errors=remount-ro,data=ordered)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev)
tmpfs on /run/lock type tmpfs (rw,nosuid,nodev,noexec,relatime,size=5120k)
tmpfs on /sys/fs/cgroup type tmpfs (ro,nosuid,nodev,noexec,mode=755)
cgroup on /sys/fs/cgroup/systemd type cgroup (rw,nosuid,nodev,noexec,relatime,xattr,release_agent=/lib/systemd/systemd-cgroups-agent,name=systemd)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
cgroup on /sys/fs/cgroup/perf_event type cgroup (rw,nosuid,nodev,noexec,relatime,perf_event)
cgroup on /sys/fs/cgroup/freezer type cgroup (rw,nosuid,nodev,noexec,relatime,freezer)
cgroup on /sys/fs/cgroup/pids type cgroup (rw,nosuid,nodev,noexec,relatime,pids)
cgroup on /sys/fs/cgroup/blkio type cgroup (rw,nosuid,nodev,noexec,relatime,blkio)
cgroup on /sys/fs/cgroup/hugetlb type cgroup (rw,nosuid,nodev,noexec,relatime,hugetlb)
cgroup on /sys/fs/cgroup/cpu,cpuacct type cgroup (rw,nosuid,nodev,noexec,relatime,cpu,cpuacct)
cgroup on /sys/fs/cgroup/memory type cgroup (rw,nosuid,nodev,noexec,relatime,memory)
cgroup on /sys/fs/cgroup/net_cls,net_prio type cgroup (rw,nosuid,nodev,noexec,relatime,net_cls,net_prio)
cgroup on /sys/fs/cgroup/devices type cgroup (rw,nosuid,nodev,noexec,relatime,devices)
cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,nosuid,nodev,noexec,relatime,cpuset)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=28,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=13386)
mqueue on /dev/mqueue type mqueue (rw,relatime)
debugfs on /sys/kernel/debug type debugfs (rw,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime)
sunrpc on /run/rpc_pipefs type rpc_pipefs (rw,relatime)
fusectl on /sys/fs/fuse/connections type fusectl (rw,relatime)
binfmt_misc on /proc/sys/fs/binfmt_misc type binfmt_misc (rw,relatime)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=202792k,mode=700,uid=1000,gid=1000)
/home/.ecryptfs/mobileme/.Private on /home/mobileme type ecryptfs (rw,nosuid,nodev,relatime,ecryptfs_fnek_sig=06f88a97693f0939,ecryptfs_sig=5159f47e93241071,ecryptfs_cipher=aes,ecryptfs_key_bytes=16,ecryptfs_unlink_sigs)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
/dev/sda8 on /media/mobileme/data type ext4 (rw,nosuid,nodev,relatime,data=ordered,uhelper=udisks2)
/dev/sda7 on /media/mobileme/Dropbox type ext4 (rw,nosuid,nodev,relatime,data=ordered,uhelper=udisks2)
sudo fdisk -l
Disk /dev/sda: 74.5 GiB, 80026361856 bytes, 156301488 sectors
Disklabel type: dos
Disk identifier: 0x0002b710
Device     Boot     Start       End   Sectors  Size Id Type
/dev/sda1            2048  21600255  21598208 10.3G 83 Linux
/dev/sda2        21736006 156280319 134544314 64.2G  5 Extended
/dev/sda5       147203595 156280319   9076725  4.3G 82 Linux swap / Solaris
/dev/sda6        21736071  75296654  53560584 25.6G 83 Linux
/dev/sda7       137661048 147203594   9542547  4.6G 83 Linux
/dev/sda8        75296718 137660984  62364267 29.8G 83 Linux
Partition table entries are not in disk order.
Disk /dev/mapper/cryptswap1: 4.3 GiB, 4646758912 bytes, 9075701 sectors
sudo blkid
/dev/sda1: LABEL="HOME" UUID="a2042427-bdf8-44d6-b613-ffe43df9811a" TYPE="ext4" PARTUUID="0002b710-01"
/dev/sda5: UUID="94835165-0ec7-4581-96e1-34524911b6e5" TYPE="swap" PARTUUID="0002b710-05"
/dev/sda6: UUID="0ef0d2d3-4a06-4acc-9103-4742e1983e0f" TYPE="ext4" PARTUUID="0002b710-06"
/dev/sda7: LABEL="Dropbox" UUID="72987730-31c6-4249-8866-2eccba033069" TYPE="ext4" PARTUUID="0002b710-07"
/dev/sda8: LABEL="data" UUID="3eacfa38-6fe1-460f-9191-8ec83b62d519" TYPE="ext4" PARTUUID="0002b710-08"
/dev/mapper/cryptswap1: UUID="11481f0f-fa21-48e7-b4e0-cf51872632e7" TYPE="swap"
Thanx agian
« Last Edit: February 06, 2018, 11:04:37 pm by Brotherred »
« Reply #5 on: February 07, 2018, 09:37:27 am »
Create the mountpoints:
sudo mkdir -p /media/mobileme/dataand
sudo mkdir -p /media/mobileme/Dropboxthen open fstab for editing:
gksudo xed /etc/fstaband add these 4 new lines at the bottom
## Automount Dropbox partition (sda7)
UUID=72987730-31c6-4249-8866-2eccba033069    /media/mobileme/Dropbox    ext4    defaults    0       0
## Automount data partition (sda7)
UUID=3eacfa38-6fe1-460f-9191-8ec83b62d519    /media/mobileme/data    ext4    defaults    0       0
SAVE the file and exit the text editor
Test fstab with:
sudo mount -aif there's no errors from that .. reboot to test
(if there are errors, post them here)
Currently those mountpoints will only be writeable by root.
If you want them read/write/execute by everyone .. run:
sudo chmod 777 /media/mobileme/dataand
sudo chmod 777 /media/mobileme/Dropbox
« Last Edit: February 10, 2018, 11:34:43 am by PCNetSpec »
Offline Brotherred
  • No0b
« Reply #6 on: February 09, 2018, 10:54:18 pm »
Excellent thankyou.
I note my lack of contributions to the community. I doubt that have much to offer.
Anyway thanx again.
Re: Automount Partitions (Solved)
« Reply #7 on: February 10, 2018, 05:43:43 am »
You're most welcome Brotherred :)
