Author Topic: remove kernel headers?  (Read 2920 times)
Offline DAMIEN1307
Re: remove kernel headers?
« Reply #15 on: January 27, 2018, 11:05:52 am »
this is what i just got in terminal the 4.10 doesnt answer...rc?...release candidates?...DAMIEN
damien@damien ~ $ dpkg -l | grep 4.8.0
ii  guvcview                                    2.0.5+ubuntu2~ppa1+1418-0ubuntu1~201702081552~ubuntu16.04.1 amd64        Gtk3 base UVC Viewer
ii  libguvcview-2.0-0:amd64                     2.0.5+ubuntu2~ppa1+1418-0ubuntu1~201702081552~ubuntu16.04.1 amd64        GUVCView - runtime
damien@damien ~ $ dpkg -l | grep 4.10.0
damien@damien ~ $ dpkg -l | grep 4.11.0
ii  gir1.2-javascriptcoregtk-3.0:amd64          2.4.11-0ubuntu0.1                                           amd64        JavaScript engine library from WebKitGTK+ - GObject introspection data
ii  gir1.2-webkit-3.0:amd64                     2.4.11-0ubuntu0.1                                           amd64        Web content engine library for GTK+ - GObject introspection data
ii  libjavascriptcoregtk-1.0-0:amd64            2.4.11-0ubuntu0.1                                           amd64        JavaScript engine library from WebKitGTK+
ii  libjavascriptcoregtk-3.0-0:amd64            2.4.11-0ubuntu0.1                                           amd64        JavaScript engine library from WebKitGTK+
ii  libwebkitgtk-1.0-0:amd64                    2.4.11-0ubuntu0.1                                           amd64        Web content engine library for GTK+
ii  libwebkitgtk-1.0-common                     2.4.11-0ubuntu0.1                                           all          Web content engine library for GTK+ - data files
ii  libwebkitgtk-3.0-0:amd64                    2.4.11-0ubuntu0.1                                           amd64        Web content engine library for GTK+
ii  libwebkitgtk-3.0-common                     2.4.11-0ubuntu0.1                                           all          Web content engine library for GTK+ - data files
damien@damien ~ $ dpkg -l | grep 4.13.0
ii  linux-generic-hwe-16.04                     4.13.0.32.52                                                amd64        Complete Generic Linux kernel and headers
ii  linux-headers-4.13.0-32                     4.13.0-32.35~16.04.1                                        all          Header files related to Linux kernel version 4.13.0
ii  linux-headers-4.13.0-32-generic             4.13.0-32.35~16.04.1                                        amd64        Linux kernel headers for version 4.13.0 on 64 bit x86 SMP
ii  linux-headers-generic-hwe-16.04             4.13.0.32.52                                                amd64        Generic Linux kernel headers
ii  linux-image-4.13.0-32-generic               4.13.0-32.35~16.04.1                                        amd64        Linux kernel image for version 4.13.0 on 64 bit x86 SMP
ii  linux-image-extra-4.13.0-32-generic         4.13.0-32.35~16.04.1                                        amd64        Linux kernel extra modules for version 4.13.0 on 64 bit x86 SMP
ii  linux-image-generic-hwe-16.04               4.13.0.32.52                                                amd64        Generic Linux kernel image
damien@damien ~ $
« Last Edit: January 27, 2018, 11:12:47 am by DAMIEN1307 »
ORDO AB CHAO
« Reply #16 on: January 27, 2018, 11:26:24 am »
Wanna know what the package status "ii" and "rc" stand for...
See the green ticked answer here:
https://askubuntu.com/questions/18804/what-do-the-various-dpkg-flags-like-ii-rc-mean
First letter -> desired package state ("selection state"):
    u ... unknown
    i ... install
    r ... remove/deinstall
    p ... purge (remove including config files)
    h ... hold
Second letter -> current package state:
    n ... not-installed
    i ... installed
    c ... config-files (only the config files are installed)
    U ... unpacked
    F ... half-configured (configuration failed for some reason)
    h ... half-installed (installation failed for some reason)
    W ... triggers-awaited (package is waiting for a trigger from another package)
    t ... triggers-pending (package has been triggered)
Third letter -> error state (you normally shouldn't see a third letter, but a space, instead):
    R ... reinst-required (package broken, reinstallation required)
« Last Edit: January 27, 2018, 11:28:04 am by PCNetSpec »
Offline DAMIEN1307
« Reply #17 on: January 27, 2018, 11:37:04 am »
OK...i cant just say thats all greek to me since i can read and speak some greek, so ill have to say, thank you for introducing me to ancient sanskrit, im now sucking my thumb in wonder and really dont have a clue of understanding what i just saw...lol...could you just let me know if what i posted as the "after" readings are in line of what you and vin were hoping to see or is anything out of line there?...lol...DAMIEN
ok i think i just had "light dawn upon marble head"...the first i = desired state...the second i = current state...the only thing left to understand then if ive got this right is why did the 4.10 series come back with nada?
just gor that one as well r = remove which is the desired state...c = only the config files are installed...i think i got it...this is what happens when you get old and just dont sleep at night like last night was for me...dont worry you'll get there to...you may not be "over the hill yet" but im sure you can certainly see the top...lo...lthen like me,  you too can slide down the razor blade of life...lol
i think in my case, Ian Anderson of jethro tull said it best...how does it feeeel, to be thick as a brick...many thanks to all of you guys for help in this matter...i got one more for ya though...on the whisker menu on the top left side there is a human figure with my name next to it...is there a way to change that avatar into my coat of arms like what i have on this post? just asking...DAMIEN
« Last Edit: January 27, 2018, 11:51:39 am by DAMIEN1307 »
ORDO AB CHAO
« Reply #18 on: January 27, 2018, 11:55:53 am »
ii = the package was meant to be installed, and it currently is installed .. there is no third letter, so no error.
rc = the package is meant to be removed, but currently the config files are still present (ie. it was 'removed' not 'purged') .. there is no third letter, so no error.
If you saw say 'ihR'...
ihR = The package is meant to be installed, but currently it is only half-installed (ie. the installation failed for some reason), so the error is telling you it needs to be Reinstalled.
I guess you can extrapolate the rest.
« Last Edit: January 27, 2018, 12:09:56 pm by VinDSL »
« Reply #19 on: January 27, 2018, 11:58:08 am »
OK...i cant just say thats all greek to me since i can read and speak some greek, so ill have to say, thank you for introducing me to ancient sanskrit [...]
Yup. There are three fields: Removed, Status, and Error
"rc" in this case means the kernel package was removed, but the configs hung around.
Looks like they're gone now. You should be good until the next time ...
« Reply #20 on: January 27, 2018, 12:10:28 pm »
I have a *feeling* this is happening when users remove kernel packages via 'Update Manager'.
Not sure if it's intentional or a bug - I suspect intentional ...
« Reply #21 on: January 27, 2018, 12:11:23 pm »
It's intentional .. configs NEVER get removed unless the user specifically chooses '--purge' .. they're NEVER removed automatically.
« Reply #22 on: January 27, 2018, 12:12:22 pm »
Cool !  :)
« Reply #23 on: January 27, 2018, 12:14:15 pm »
Er...
I was dancing on the keyboard are accidentally erased your message.  :-[
Can you get rid of that '666' please?
Offline DAMIEN1307
« Reply #24 on: January 27, 2018, 12:27:01 pm »
hey vin...i got rid of the tripple ripple for ya...always remember that it was a real honest to goodness church going, bible thumping, Christian that gave ya the triple sixes...lol...DAMIEN
ORDO AB CHAO
« Reply #25 on: January 27, 2018, 12:40:06 pm »
THX!
Stuff like that really freaks me out. No kidding  8)
« Reply #26 on: January 27, 2018, 12:44:41 pm »
"-rw-rw-rw-" is part of the little message under my avatar on the left :)
