Author Topic: Is it possible to install peppermint on hard drive I want?  (Read 776 times)
Offline Tomsonas
« on: January 24, 2018, 06:28:16 am »
I have two hard drives on my pc. If I install peppermint os will I get option to install to drive I want? I installed mageia linux and it didn't give me an option to choose drive.
Re: Is it possible to install peppermint on hard drive I want?
« Reply #1 on: January 24, 2018, 06:33:19 am »
It should give you an option.  (Peppermint, I can't speak for Mageia)  You may have to choose "Something Else" under the install options, to be sure you select the correct drive, but I don't see why it wouldn't work.  It worked for me in past versions, where I had multiple hard drives.
Offline Tomsonas
« Reply #2 on: January 24, 2018, 06:35:43 am »
Oh, but I have mageia installed now and I want to replace it. What do I have to do then?
« Reply #3 on: January 24, 2018, 08:28:24 am »
Which drive (sata1 or sata2) do you want to install it on ?
what's on the other disk .. an OS ?
Can you boot to the Peppermint LiveUSB, open a terminal, and post the output from running these commands:
sudo fdisk -land
sudo blkidso we can get a picture of your current partition layout.
« Last Edit: January 24, 2018, 08:30:53 am by PCNetSpec »
