Author Topic: Post Meltdown, Spectre and other Intel issues  (Read 10943 times)
Re: Post Meltdown, Spectre and other Intel issues
« Reply #30 on: January 24, 2018, 11:01:27 am »
Did you guys see my first post in this thread? WD (hard drive manufacturer) collaborating with RISC-V (open source cpu), so who knows?
« Last Edit: January 24, 2018, 11:02:59 am by pin »
« Reply #31 on: January 24, 2018, 12:19:20 pm »
Something tells me WD aren't planning on utilising the RISC-V ISA to get into the 'PC' CPU fabrication business .. but sure, never say never :)
« Reply #32 on: January 24, 2018, 12:29:57 pm »
You might be right! It's always about second intentions, isn't it?
At least we can hope for a pleasent side effect [emoji6]
« Reply #33 on: January 26, 2018, 03:53:52 am »
« Reply #34 on: January 26, 2018, 06:56:18 am »
Yep, expect a  LOT of updates around this .. and you'd be well advised to stay on top of them.
« Reply #35 on: January 26, 2018, 07:06:33 am »
No problem with that. They are easily updated, both on Peppermint and on Void. My annoyance is with my daughter's Bodhi system [emoji26]... Bodhi doesn't update kernels in between releases, so every two days or so I'm refreshing the packages and intalling new kernels on her laptop through Synaptic. Not difficult, just borring!
EDIT: Maybe this could actually be automated using a script to fetch the latest kernel from the Ubuntu repos instead?! Probably, worth looking into it...
« Last Edit: January 26, 2018, 07:11:22 am by pin »
« Reply #36 on: January 26, 2018, 07:38:06 am »
I'd 'assume' that'd be doable, but I don't know enough about Bodhi to know for sure (or I'm afraid to be much help).
« Reply #37 on: January 26, 2018, 08:07:56 am »
That was not my intention [emoji6]! I don't expect to get help with another distro.
If I were to decide, she would be running Peppermint...
Anyway, just got her to the new kernel AGAIN!
« Reply #38 on: January 26, 2018, 08:18:04 am »
« Reply #39 on: January 29, 2018, 08:50:17 am »
Linux 4.15 Released With Improved Meltdown, Spectre Patches
eWeek article: https://goo.gl/1QChtH
LKML announcement:  https://goo.gl/gj6Zi1
« Reply #40 on: January 29, 2018, 09:13:04 am »
Works ...
« Reply #41 on: January 29, 2018, 10:31:32 am »
Did you just install it as it or did you unload nvidia first install it and then reload nvidia ?
« Reply #42 on: January 29, 2018, 10:41:07 am »
I installed it, as is - didn't bother compiling it, et cetera. Recognized nVidia 390.12 just fine.  ;)
Here's a link to the binaries:  https://goo.gl/wubzDQ
« Reply #43 on: January 29, 2018, 10:52:49 am »
 ??? Fixed on the 4.14.15 also
[pin@awesomevoidmusl ~]$ uname -a
Linux awesomevoidmusl 4.14.15_3 #1 SMP PREEMPT Sun Jan 28 22:13:16 UTC 2018 x86_64 GNU/Linux
[pin@awesomevoidmusl ~]$ cat /sys/devices/system/cpu/vulnerabilities/spectre_v2
Mitigation: Full generic retpoline
??? Sorry, on Void again
Should get that 4.15 on my PM7 soon....
« Reply #44 on: January 29, 2018, 10:54:09 am »
Well that worked... on Elementary OS - I wasn't going to test it on my Pep - I'll wait for official releases here   :D
