Author Topic: Allowing automatic flash content in Chrome/Chromium >= 62 (fixes SSB's)  (Read 3352 times)
In Chrome / Chromium 62 (and greater) Google saw fit to remove the ability to always play flash content without being asked first. This broke SSB's that display flash content because the user never gets prompted whether they want to allow flash content or not.
The solution is to whitelist all http and https sites in Chrome/Chromium allowing automatic playing of flash content without being prompted.
So open Chromium/Chrome.
In the address bar enter:
chrome://settings/content/flash
and hit Enter.
On the "Allow" line, click the "ADD" button.
set the site as:-
http://*
and click the "ADD" button
On the "Allow" line, click the "ADD" button again
set the site as:-
https://*
and click the "ADD" button.
Also make sure the switch at the top of that page is set to "Ask first (recommended)" and NOT "Block sites from running flash".
(click image to enlarge)
you can now check this worked by closing ALL running web browser instances then testing if the:-
Menu > Graphics > Editor by Pixlr
SSB works .. if it does, you're all done.
« Last Edit: January 13, 2018, 01:34:39 pm by PCNetSpec »
Re: Allowing automatic flash content in Chrome/Chromium >= 62 (fixes SSB's)
« Reply #1 on: January 13, 2018, 01:48:09 pm »
If the above on it's own doesn't get flash working in Chromium, check whether you have the adobe-flashplugin installed and NOT flashplugin-installer
You can do this by going to:-
Menu > Preferences > Software & Updates
Select the "Other Software" tab.
And make sure there is a tick next to
Canonical Partners
Enter your password, if prompted.
Once the box is ticked, click the "Close" button, followed by the "Reload" button if offered.
Now open a terminal and run:
sudo apt-get updatethen
sudo apt-get install adobe-flashpluginand accept the changes.
Now close ALL running web browser instances and check if
Menu > Internet > Editor by Pixlr
works
« Last Edit: January 13, 2018, 01:52:01 pm by PCNetSpec »
