Author Topic: Gnome desktop - my frustration  (Read 4235 times)
Offline rickc
« on: January 10, 2018, 02:40:15 am »
I've really got to like Gnome. but I haven't found the right distro to implement it.
Ubuntu Gnome is discontinued. Ubuntu 17.10 is buggy, although the first long term release should be better.
I've been using Antergos for a month, loved it at first, but without having installed anything other than Chrome, it's already getting glitchy.   Installing Gnome in distros such as linux mint is very problematic, I'm told.
Once again I'm back to the same conclusion I've had for ages now, that Peppermint is the most solid OS there is.   Unfortunately for me, the DE ain't Gnome...
I'm probably being really cheeky even asking, but is there any chance of Gnome edition of Peppermint?
Offline Crazy Tux
  • Peppermint version(s): 5
Re: Gnome desktop - my frustration
« Reply #1 on: January 10, 2018, 03:38:04 am »
Did you tried Fedora or OpenSuse???
Also remember this, you're not quit correct with your opinion about Ubuntu 17.10. It's correctto say that 17.10 is a "ïn-between" Ubuntu version but it doesn't mean it is completly buggy. One factor that makes your operating system buggy is your desktop system or laptop. If you are using hardware which contains some small (factory production) mistakes/errors/issues, (as example faulty condenser on your motherboard or a badly produced not dectected hard drive) this will have it's own affect on the operating system as well. With Ubuntu it is better to wait for the LTS version since this version will be supported for a couple of years giving the developers time to resolve issues.
« Reply #2 on: January 10, 2018, 07:29:45 am »
Hi rickc,
I am pretty sure that the chances of PeppermintOS coming out with a Gnome edition are zero (or less  :P ). The reasons are: 1) PeppermintOS is made by a very small team and we do not have the human resources available to do this; and 2) Gnome is much too heavy for a distro like PeppermintOS (in other words: it just does not fit into our philosophy about how this distro should be).
Your only real option is to try to install it yourself, but I would not advise this unless you really know what you are doing!  ;) If you nevertheless decide to go that route then be informed that probably no one on the team can really help you very much if you run into trouble.
Reason for edit: grammatical error corrected.
« Last Edit: January 10, 2018, 07:31:32 am by Slim.Fatz »
Offline rickc
« Reply #3 on: January 10, 2018, 01:18:33 pm »
I can't get on with Fedora at all for some reason, and I found OpenSuse a bit slow.   The gnome experience on Ubuntu Gnome was faster.  Yeah, the LTS may be a good option for me.   I don't think my Dell Latitude is the problem, it certainly runs Peppermint flawlessly!
I think because of smart phones etc, I simply do less now on my laptop then ever before.   A nice browsing experience, work stuff, a DE I like that's fast and professional looking....that's all I need these days.
Offline tetricky
  • Peppermint version(s): 8, 9
« Reply #4 on: January 10, 2018, 03:21:48 pm »
I'm out of step with most of the rest of the world.  I like Gnome. I like that I can support users (write cross platform user guides) with potentially different underlying OS's depending on role, support requirements, and age.
Consider Debian Stretch. It's very current, and will be as stable as a stable thing for years (but will gradually fall behind the leading edge the longer you use it). It's hard for me to judge how fast/slow it is.  On this machine there is absolutely no slowdown of anything (but it's a very capable machine). If you need something more corporate, well out of date, but equally stable - and RPM based (and potentially the same platform as your webhosting or VPS), with a potential support option, then possibly Centos 7 (this is an edge useage case, I might be the only one...).
I'm currently debian on the desktop (it's more up to date AND more stable than Ubuntu 16.04), peppermint on the laptop. Centos in the cloud. I started on Suze, never got on with it. I'm currently using fedora atomic for K8's cluster builds. I find fedora itself a bit unfinished sometimes, and I have grown wary of rolling update distributions because it seems that something is always broken (it might be me).
This is the great thing for me about linux, you can tailor the tools to the job.
« Reply #5 on: January 10, 2018, 09:55:35 pm »
Give Solus Gnome a try  (but be aware their software repository is limited when compared to other "Mainstream" Distributions)
ps see you back on Peppermint REAL soon   :D  :D  :D   there is no substitute
« Reply #6 on: January 11, 2018, 03:20:51 am »
Coming from me, this is quite obvious but,... here we go!
If you have the patience and time to do it, you could try Void linux, it has gnome 3.26.0 in the repos.
Now, there's no gnome ISO available. You have to do a base install, followed by Xorg and then gnome.
As Zeb said, seen you soon again here in Peppermint!
...or maybe, seen you soon on the other side, i.e Void
Regards
« Reply #7 on: January 11, 2018, 07:06:35 am »
Afraid not my friend, not without some kind of seismic shift in our ethos.
Offline christianvl
« Reply #8 on: January 11, 2018, 12:40:01 pm »
Lot's of options for you to try. Mageia, Manjaro and Sabayon are very different from each other and all have Gnome editions.
Offline rickc
« Reply #9 on: June 19, 2018, 01:20:30 pm »
Been enjoying MX linux, which works well with Gnome.    Been using it for some months now, and I've found it very stable.  So instead of dual booting with windows, I'm now triple booting. Gnome is great (once you've fine tuned it) - but the speed of Peppermint with ICE still makes this the best distro for browsing
So I'm no longer frustrated - I can scratch my gnome itch when I like and stay here too. All good :)
On the less good side, I test drove Ubuntu 18 LTS and found it quite slow and buggy.  It's not a great implementation of Gnome imo, although I accept it's horrible everywhere until you tweak it extensively.  I think it feels rushed.
« Reply #10 on: June 19, 2018, 02:55:10 pm »
Ubuntu 18.04 is one of those distro's where some people seem to love their Gnome implementation and others hate it .. Marmite springs to mind.
(except I like Marmite:)))
The PoorGuy
  • Guest
« Reply #11 on: June 20, 2018, 09:00:23 am »
« Last Edit: August 27, 2018, 08:08:48 pm by The PoorGuy »
« Reply #12 on: December 25, 2018, 05:48:19 am »
I looked at Ubuntu's 18.10 GNOME distro yesterday for about an hour, and I got pretty frustrated with it quite quickly.  I wanted to move an old wallpaper from an external hard drive to its backgrounds folder, but then realized GNOME is very difficult to open as root. (I got nothing out of right clicking.)  I'm sure that's by design to protect against someone tampering with your OS, but for me it was just a little too much.
Don't get me wrong, Ubuntu is a nice distribution, but GNOME is a study all on its own.  I really do find an Xfce interface a much simpler interface to work with.
« Reply #13 on: December 25, 2018, 07:07:14 am »
Hi perknh,
You can always do it from the CLI  ;)
« Reply #14 on: December 25, 2018, 12:02:30 pm »
Yeah but why should you have to .. they've dumbed it down to the lowest common denominator .. making it an anathema for most 'Linux' users, who prefer power over simplicity.
Gnome IMHO are heading towards making the desktop 'device' like.
« Last Edit: December 25, 2018, 12:05:29 pm by PCNetSpec »
