Author Topic: #SpectreAndMeltdown  (Read 3494 times)
Re: #SpectreAndMeltdown
« Reply #15 on: January 08, 2018, 02:27:59 pm »
Here is a tool to check system vulnerability https://github.com/speed47/spectre-meltdown-checker
« Reply #16 on: January 09, 2018, 11:53:09 am »
Hum! Has anyone got the Ubuntu KTPI patched kernel today?? It was supposed to be released today!...
Offline DAMIEN1307
« Reply #17 on: January 09, 2018, 03:04:53 pm »
hi pin...i havent seen it yet from peppermints update manager but did see it on my linux mint update manager on my other computer with the AMD chip...curiously though that even though mint said it was updating 4.4 series and 4.13 series kernels, i only saw the 4.4 series download in the specs...also take note of message from Ubuntu..."The Rolling HWE kernel for Ubuntu 16.04 will go to 4.13 early, instead of also fixing 4.10 HWE kernel."...so the 4.10 series kernel that most peppermint users have been using, it looks like we will have to at a minimum either regress to the 4.4 LTS series, or upgrade to at least the 4.13 HWE series kernels in order to have the kernel security update applied...will keep you all informed if i find out more...sorry i couldnt tell ya more than that...DAMIEN
« Last Edit: January 09, 2018, 03:14:02 pm by DAMIEN1307 »
ORDO AB CHAO
« Reply #18 on: January 09, 2018, 08:03:59 pm »
[emoji106][emoji106]
Thx!
Online murraymint
« Reply #19 on: January 10, 2018, 05:27:31 am »
This came through yesterday for Peppermint 7:
4.4.0-108-generic #131-Ubuntu SMP Sun Jan 7 14:34:49 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
EDIT:
and just now:
4.4.0-109-generic #132-Ubuntu SMP Tue Jan 9 19:52:39 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
« Last Edit: January 10, 2018, 05:57:47 am by murraymint »
« Reply #20 on: January 10, 2018, 06:16:20 am »
Thanks!
Will be loading those as soon as I get home... ;)
