Author Topic: Trying to install linux on new laptop  (Read 2631 times)
Offline sandstormzach
  • Linux Noob
« on: July 11, 2014, 10:09:35 pm »
Okay, after months of saving money and debating whether or not to spend it, I got a new computer last week. It's a Toshiba, running Windows 8 (which is honestly better than I had heard), and I want to set up a partition for Linux on it. I got it to let me boot from the CD/DVD drive, and used a Ubuntu Gnome disk mostly as a test.
And the installer is telling me the computer already has 5 partitions.
Partitions 1, 3, 4 and 5 are all ntfs. Partition 4 seems to be my primary partition considering it takes up over 90 percent of the space on this thing. Partion 2 is an efi/fat32 (depending on what part of the installer you look at), and I'm not even sure what that is. Have any of you guys encountered this before? If so, what did you do?
Re: Trying to install linux on new laptop
« Reply #1 on: July 12, 2014, 04:56:55 am »
Boot to the LiveCD, and run:
sudo fdisk -lthen post the output back here.
I'm going to guess you have a GPT partition table which doesn't suffer the maximum of 4 primary partitions limit .. but at this point that's just a guess.
  • Linux Noob
« Reply #2 on: July 12, 2014, 09:20:27 am »
Okay, here's the output.
Disk /dev/sda: 750.2 GB, 750156374016 bytes
256 heads, 63 sectors/track, 90845 cylinders, total 1465149168 sectors
Disk identifier: 0x00000000
/dev/sda1               1  4294967295  2147483647+  ee  GPT
ubuntu-gnome@ubuntu-gnome:~$
« Reply #3 on: July 18, 2014, 11:25:08 am »
Yup GPT .. I think you're only option would be to select "Something else" during the partitioneing phase of the installer and manually shrink the partitions and set up the new ones.
I can't say I've ever done this myself, so I understand little about how the installer handles GPT.
